Starting problem and fuel pump
Started by kaalkoejawel, August 24, 2010, 09:28:42 AM
kaalkoejawel
hi guys
so i got my second FJ1200 (the donor for my project) running, and all seems well, the bike runs nice and smooth and is very powerful.
but, when it is hot is stuggles to start. it did stand for a while and i have not tested the battery yet, but when it is cold the motors turns a lot faster when starting. when it is hot it sounds like the battery is flat. has anybody experienced this before?
then, i am looking for a fuel pump for this donor bike. i am currently using the project bike's pump. what other bike's or other types of pump can be used.
cheers!
almost done!
FUEL PUMPs   Part No      Pressure Range   Max. Flow
  Brand      FED-40104    1.5 – 3.5psi   28 gph
  FEDTRO      FED-40105    2.5 – 4.5psi   30 gph
   Sold on Ebay.au by       the_auction_broker  (Philip Island)
* FuelFlo        015        1  -  4psi   23 gph  1.5Lpm
   Repco supplied for A$110.00
Airtex -       ES8016S      2.5-4.5 PSI   30 GPH
5/16" hose barbs   It is a solenoid pump that stops fuel if no power
There are others too.  You need to be able to mount it and get the fuel hoses to and from.
You also want a low pressure pump like those above, not a pump for a fuel injected engine.
it also helps to crack the throttle a touch when hot starting.
kaalkoejawel
Quote from: racerman_27410 on August 24, 2010, 07:00:29 PM
thanx frank, but it doesn't help if the motor is not turning fast enough to start.
changed the battery , but still no luck - but then again, this battery might be buggered as well!  :scratch_one-s_head:
almost done!
oldktmdude
  I had the same problem recently. Started fine when cold but would not crank fast enough to fire when hot. Bump-started easily. I replaced the starter and has been fine since. Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
TRoy
Quote from: kaalkoejawel on August 25, 2010, 02:07:51 AM
...thats the whole point of cracking the throttle, so the engine WILL turn fast enough to start. Have you tried it?
OTOH I have a starter here that I would love to sell you  :sarcastic:
Peace & Love
86FJ 100K+
07Burg650
15Downtown300
kaalkoejawel
Quote from: oldktmdude on August 25, 2010, 04:47:13 AM
bugger! i was hoping it would not be the starter but rather someting simple, like a bad earth connection.
almost done!
kaalkoejawel
Quote from: TRoy on August 25, 2010, 06:31:34 AM
ok, maybe someone should explain to me what exactly "cracking the throttle" means. i don't see how opening the throttle will make the engine turn faster.
how much do you want for the starter?
almost done!
kaalkoejawel
i just put in a new battery, but no luck. must be either the starter or bad wiring.
almost done!
Quote from: kaalkoejawel on August 25, 2010, 07:29:07 AM
Opening the throttle perhaps 1/8 of its total travel when starting.
Allows more air in to the engine, reducing the amount of vacuum that the pistons see, which lowers the resistance to rotation at the starter.
kaalkoejawel
thanks, ill give it a shot.
do all FJ models use the same starter motor?
almost done!
RichBaker
Take the starter apart, clean and lube the bushings and clean up the contact surfaces with scotchbrite and contact cleaner. A broken hacksaw blade can be used to clean the grooves in the armature surface.  Usually all the starter needs to be good again....
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
kaalkoejawel
Quote from: RichBaker on August 25, 2010, 07:29:12 PM
cool, thanx!
almost done!
DailyDriver
Quote from: andyb on August 25, 2010, 08:00:48 AMOpening the throttle perhaps 1/8 of its total travel when starting.
I understand what you are saying. My bike won't start unless I crack the throttle hot or cold. But, wouldn't allowing more air into the cylinders as the engine is cranking also increase the compression, further adding to the resistance, i.e. the pistons pushing against a higher volume vs. pulling a higher vacuum? Just wondering as I sometimes tend to overthink things.  :wacko3:
Only a motorcyclist knows why a dog sticks its head out the window of a moving car.
Thus cracking rather than WOT.  Just to reduce the vacuum in the cylinder, but not create huge amounts of pressure (compression).
