fuel pump
Started by 1989fj1200russ, August 07, 2010, 09:28:35 PM
1989fj1200russ
ok got a fuel pump off a 2000 royal star yamaha . its the same as my old one that came off my 89fj. the only thing that was not the same is the end where the fuel lines  hook up the pipes .they where one size bigger and pipes did not line up with the gas lines like the old one .so i took the old end cap off the old pump and installed on the new pump i got and it works fine for now .if you try this make sure you line up the rubber part inside the pump with the end where the pipes are you can see the   imprint on the rubber. later and have  fun riding
fj1250
I maay have a stock pump you can have for the postage if your interested.
MC
1989fj1200russ
wow thats cool dose it work ? and if it works lets talk about it ok let me know ok thanks
