The pressure of radial bias
Started by pdofak, July 26, 2010, 02:55:44 AM
pdofak
Hi,
Sorry I'm such a lurker. I work out of town now and don't have much internet access. ( Also means I don't have any FJ access either! )
So here's a question,
Book says tire pressures of 32/36 F/R. That was for bias tires. Does the group have experience and comments for pressures in modern radials? should I run OEM pressures or should they trend up? How much?
I had a front Avon cup badly and be done way before the rear.
Thanks,
Patrick
Go by pressure rise, myself.
Cold is <x> psi.  Hot should be 10% higher.  Adjust <x> until you're hitting that amount of change.
As a starting point, especially with radials 36F, 42R is good.
Then go by AndyB's suggestion of a 10% rise.
pdofak
Thanks, I'll have a give that a go.
