What to do???
Started by fjpigtobe, July 19, 2010, 11:39:28 PM
fjpigtobe
yeah, not exactly sure of the right name..left hand side cover, also need the rotor and pick ups (again not certain of names).
Start by going to a parts fische and seeing what they are :)
Here is the rotor/pickup diagram.
Here is the diagram for the covers, the one you want is the bottom left of the picture.
Oh, and you'll need to go in there and measure.  If it did enough damage to take the rotor out, it'd be no shock to find the crankshaft has been bent.
Jevan........ I have most of the motor from my parts bike...... If you identify what you need, let me know if I can help.
I'm up on the Sunshine Coast Qld.
Cheer
fjpigtobe
cheers harvy and andyb,
definately need cover, after that I can't be certain- I think it's fair to say.
Hopefully this picture works(and is clear enough), if not hopefully the link below will.
This photo shows what is left.  To my knowledge(as I didn't pull it down), there are not other parts. So the rest, and what's damaged, needs to be purchased.  Is anyone able to tell me what I need and/or what looks to be damaged?
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs170.snc4/37823_1518096962584_1539327660_1293161_789834_n.jpg
Thanks guys.
Jevan........ looks like there are a couple of cover bolt holes that are broken on the case?....hard to tell...pic is a bit out of focus.
Yes I have a cover for you and the internals under it if necessary.
It would appear that your Oil filter housing is missing also........ got one of them too.....
send me a PM mate and we can work something out.
fjpigtobe
hey,
yeah couple of bolts snapped off in casing.  Don't think they'll be too hard to get out.oil filter housing all good, just taken off.
definately need part 1(base, pickup) in linked diagram not sure about 2(rotor). rotor looks good to me but needs further inspection and sounds like it might be wise to through in gear and spin back wheel.
http://www.boats.net/parts/search/Yamaha/Motorcycle/1984/FJ1100L/PICKUP%20COIL%20GOVERNOR/parts.html
weymouth399
Some times if the screws have not been out, the loctite on the factory bolts can be a pain so a little heat to loosen the loctite is needed.
Bob
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
fjpigtobe
thanks bob, not ready to do it yet but will keep that in mind.  want to chase up the majority of parts first.
OK Jevan, I've finally got around to pulling those parts out of the spare engine.
Looks like the parts were changed considerably between Gen1 and Gen3 FJs.
Gen1 - http://www.boats.net/parts/search/Yamaha/Motorcycle/1984/FJ1100L/PICKUP%20COIL%20GOVERNOR/parts.html
Gen3 - http://www.boats.net/parts/search/Yamaha/Motorcycle/1990/FJ1200A/PICK%20UP%20COIL%20-%20GOVERNOR/parts.html
So I'm not sure if these parts are going to work for you.
I'm pretty sure the cover will be ok.
Does anyone know if the '90 parts are going to work in an '84 ?
fjpigtobe
hmmm...thanks mate, I see what you mean...bugger
fjpigtobe
was going to question whether anything could be modified to fit gen 3.  But as the plugs different I imagine it would be more hassle than it's worth.
fjpigtobe
well, got my forks today..$220. will now do the seals just because it will be easier now than if ever they need doing in future.
does any one know if buying fork seals off ebay is recommended?
http://cgi.ebay.com.au/Yamaha-FJ1100-1984-1985-Models-FJ-1100-Fork-Seals-/390159174783?pt=AU_Motorcycle_Parts_Accessories
-cheers
weymouth399
GYMP (stock) the only way to go
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
fjpigtobe
Harvy has been a champion and spotted me a side cover and pick-up and rotor-thanks mate...but the pick-up and rotor are gen 3 as opposed to gen 1.  Would i be able to cut and connect the plugs so the gen 3 parts fit the gen 1 signal box?
weymouth399
The 84-87 take a different p/u plate and rotor than the later models.
86 plate has two pick ups on it and the later model have one.
Also the rotors are also different, being that the p/u are different.
I have plenty of rotors, but no good stater plates.
If you use these parts you will need the CDI box also and change alot of connectors.
Hope this helps
Bob
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
