Is there a trade secret
Started by 5speed, Yesterday at 04:40:33 PM
5speed
to putting one of these beast  on the center stand?
I could put my 1100 wing on the center stand with one hand..
If feels like the front wheel is welded to the floor trying to put my fj on it.
1986 FJ1200
2000 Roadstar
1976 GL1000
1978 GL1000
1982 GL1100 (sold)
T Legg
My FJ is much easier to put on the centerstand than my cb 750.
 I just grab the left handle bar grip with my left hand push and hold the kickstand down with my left foot slip my right hand through the slot in the right side cover grab the handle and lift straight up and it pops right up on the stand with ease.
T Legg
5speed
Quote from: T Legg on Yesterday at 06:05:16 PMMy FJ is much easier to put on the centerstand than my cb 750.
That's what I do as well but I have to put everything I got into getting it on the stand. Its almost like the stand mounting point is to far back.
1986 FJ1200
2000 Roadstar
1976 GL1000
1978 GL1000
1982 GL1100 (sold)
Try parking the rear wheel about an inch higher than the front (piece of wood). Then try the center stand again. It will be easier. With the rear raised on my 89, the center stand is not an issue. I now park with the wood under the center stand when I lube the chain or work on the rear.
Waiex191
I find my FJ is getting heavier as I get older, and my right knee is bad. What I have been doing is to make a halfhearted attempt to get it on the stand, let it sink down on the suspension, then go for it on the rebound.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
T Legg
The kickstand pivot bolts develop deep grooves over time . The holes in the kickstand that the pivot bolts go through get elongated and oval shaped at the same time. The centerstand will begin to hang low when in the up position.
  I think RPM still has the pivot bolts.
T Legg
