FJ1100 won't run in neutral with sidestand down
Started by Gearbox Paul, February 25, 2026, 10:14:54 PM
Gearbox Paul
I'm having trouble figuring this out.  1985 FJ1100.  Bike starts and runs fine in neutral with the kickstand up.  When I lower the kickstand (with bike still in neutral), the starter cranks over but the bike won't start.  When running in neutral, if I lower the kickstand, the bike dies.  If I pull the clutch in, bike will run in neutral or in gear with the kickstand down (or up).  And when the bike is in neutral, the neutral light on the dash always lights up.
so far I tested the kickstand safety switch and I get no continuity when it is down and low resistance (about 40 ohms) when it is up.  It's supposed to have full continuity (0 ohms) when up, so I don't know if 40 ohms is close enough to full continuity, or not.
I also tested the side stand relay and the results don't make any sense to me.  The resistance across the powered leads reads 75 ohms which is within spec.  When I apply power to these leads, I can hear the relay clicking.  With power applied, I have no continuity (infinite resistance) across the other two leads, and without power, I have full continuity (no resistance).  this is the opposite of what should happen, according to the service manual.
I haven't tested the neutral light switch yet.  But the green neutral light is working.  It is possible to have the neutral light working but the switch failed ??
I'm a little lost.  Hopefully my description above isn't too confusing.
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
Billy Bananahead
I thought that what you are describing is right. Is what you're doing all with the bike on the centre stand?
It's a safety switch to stop you riding off with the side stand down. Unless i'm reading it wrong.
Mine starts and runs in neutral with the side stand down (with and without the clutch pulled in).
If pull in the clutch and put the bike into gear with the engine running and the stand down, the bike cuts out, so I can't ride off with the side stand down. That's the way it's supposed to work  :good2:
Gearbox Paul
Quote from: Billy Bananahead on February 26, 2026, 06:50:34 AMI thought that what you are describing is right. Is what you're doing all with the bike on the centre stand?
You're reading it wrong.  The bike will not run (no ignition) in neutral with side stand down.  That's my problem.
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
Gearbox Paul
Quote from: Millietant on February 26, 2026, 07:43:46 AMMine starts and runs in neutral with the side stand down (with and without the clutch pulled in).
Yes, I'm aware of how it is supposed to work.  Mine won't run in neutral with the side stand down.  That's what I am trying to troubleshoot.
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
T Legg
 It could be a bad diode in the diode block #27 on the factory manual schematic.The kickstand relay contacts when closed ground out the ignition control and prevents the spark plugs from firing. When the kickstand is up it closes the switch and gives the kickstand relay coil a path to ground energizing the coil and causing the relay contacts to open up ungrounding the ignition module and allows spark. There is a second path to ground for the kickstand relay coil that goes through a diode to the nuetral switch to ground. If that diode goes out then the only way to ground for the kickstand relay is through the kickstand switch.
T Legg
T Legg
T Legg
Bones
Do you have the standard clutch master cylinder fitted, I fitted an FJR1300 clutch master to mine that had three prongs on the clutch switch instead of the FJ's two and no matter which way the wires were fitted on the prongs everything seemed to work backwards to normal, like bike would start in gear with clutch out etc.
I had to pull the switch apart and delete one prong and bend and move another one around so the plug would fit on and now everything works like it should, had me stumped for a while though.
93 fj1200
79 suzuki gt250x7
Gearbox Paul
Quote from: Bones on February 26, 2026, 02:32:47 PMDo you have the standard clutch master cylinder fitted, I fitted an FJR1300 clutch master to mine that had three prongs on the clutch switch instead of the FJ's two and no matter which way the wires were fitted on the prongs everything seemed to work backwards to normal, like bike would start in gear with clutch out etc.
My clutch switch has only two prongs...
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
Gearbox Paul
Quote from: T Legg on February 26, 2026, 01:45:37 PMIt could be a bad diode in the diode block #27 on the factory manual schematic.The kickstand relay contacts when closed ground out the ignition control and prevents the spark plugs from firing. When the kickstand is up it closes the switch and gives the kickstand relay coil a path to ground energizing the coil and causing the relay contacts to open up ungrounding the ignition module and allows spark. There is a second path to ground for the kickstand relay coil that goes through a diode to the nuetral switch to ground. If that diode goes out then the only way to ground for the kickstand relay is through the kickstand switch.
You may be onto something.  I'm looking through the wiring diagram and circuit diagram and if one of 2 the diodes that supply current to the neutral switch failed open (no current flow), it might explain what I am seeing.  I'll need to pull that diode block and test it with the wiring diagram.  Good thought.  I'm away from home at this time and returning in a week.  I'll report back.
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
Gearbox Paul
Quote from: Gearbox Paul on February 27, 2026, 09:49:52 AM
Resolved.  Got home last night and tore into that this morning. I pulled the diode block off the bike and tested both diodes that are connected to the neutral switch.  Sure enough, the diode between the Blue/Yellow wire and the Sky Blue wire had failed and had no current flow in either direction.  Other diode tested fine. I had some 1N4001 diodes at home from another project, so I bypassed the failded diode and spliced in a 1N4001 diode between the two wires.  Works as it should now.  Good call T Legg.
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
T Legg
I'm glad to hear you have it fixed.
 A good color coded complete wiring schematic really helps. I keep a copy of it in my tool pouch and a picture on my phone. The Yamaha owners manual that comes with the bike has a complete schematic but its point to point not set up like a ladder diaghram also very small and hard to see without a magnifying glass.
T Legg
Gearbox Paul
Quote from: T Legg on March 06, 2026, 05:26:22 PMI'm glad to hear you have it fixed.
Thanks again.  I found the circuit diagram in the service manual unnecessarily confusing regarding the wiring around the diode and the clutch switch.  I see that you've used white out and redrew some of the wiring lines on your marked diagram to clarify it.  I found your version of the electricial circuit much more useful than what is in the service manual.
Also, the testing information for the side stand relay, on page 6-18 of the service manual, is incorrect.  The manual says that the relay contacts should close when the coil is powered up, and open with no power to the coil.  That's wrong, the relay contacts are closed (0 ohms) when the coil sees no power, and they open when the coil is powered up.
1985 FJ 1100
1996 GSXR 750
1999 Ninja ZX-9R
T Legg
Quote from: Gearbox Paul on March 07, 2026, 09:43:33 AM
When trying to figure out a problem on my bike I too found the diaghram in the factory manual didnt make sense and couldnt possibly work as drawn. I redrew the lines to make it work . Later I traced out the wiring diagram in the owners manual that comes with the bike and found that it matched my redrawn schematic and that the factory repair manual was incorrect.
T Legg
JTNWEvo
I am having the same issue (not running with side stand down while in neutral) on a 1990 FJ1200 that I am fixing up. I don't see a diode block like on the FJ11, does any one know where diodes might be physically located in the wiring harness?  If I am reading the wiring diagram correctly they do seem to exist but not in a big block like the older bikes.
Open to other ideas of solutions.  My clutch and side stand switches are all working as expected when tested with a multi-meter and the neutral light comes on when in neutral and turns of when in gear.
Thanks!
