Ideas on removal of insert from cylinder
Started by moparman70, January 21, 2026, 10:34:38 AM
This is like the "Make it Work" scene in Apollo 13. Problem solving...
Flynt
Quote from: FJmonkey on Yesterday at 10:34:34 AMThis is like the "Make it Work" scene in Apollo 13. Problem solving...
I agree...  put off the mechanic's fingers for a while.  I'm sure there's a harder way that'll work.
T Legg
Quote from: Flynt on Yesterday at 10:36:39 AM
The claw was their first method attempted.
  "We have a bore scope and we can see it -- we also are able to grab it with some flexible wire pinchers but the unable to retrieve it with the pinch grabbers due to the overall width of the grabbers once they hold the brass insert.  So basically can pull it through the hole."
T Legg
86FJNJ
what about a drop of fast curing super glue on the tip of the straw. you said you kind of got it with the straw so maybe some superglue on the straw edge and then once the straw touches the piece hold it for a minute or two and then try to vacuum it out
Eric, Robert and I agree, the secret to success is with adhesives.
If you can't mechanically grab it, or hold it with vacuum, then as Timothy Leary suggested, better living thru chemistry...so to speak.
Can we start a betting pool? I'm in for 5 bucks... :gamer:  :gamer:  :gamer:  :gamer:
Waiex191
I'd wrap some good duct tape inside out around a straw.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Billy Bananahead
Bite the bullet and pull the head off. Then clean the carbon off the valves and piston crowns. (popcorn)
