Steve's 1985 FJ1100 restoration in San Diego
Started by STLanduyt, January 03, 2026, 08:57:22 PM
Bones
Randy at RPM used to sell those engine bars that's where I bought mine from for my 3xw. He had them for all models at the time.
93 fj1200
79 suzuki gt250x7
RPM - Robert
Unfortunately Renntec sold several years back. When they did they jacked the dealer pricing up. That plus the several hundred dollars to get them from the UK to the US made it not feasible for us to continue to carry them when people could buy them direct for cheaper.
That said I don't think they make them for the FJ anymore. The part numbers were 10019 and 10021 for the two models they made.
Quote from: STLanduyt on January 22, 2026, 12:44:40 PMDean,
Thank you for your update, and offer to assist in acquiring the engine guards.
If the model year makes a difference in the fit of the engine bars, I have a 1985 FJ1100.  The re-powder coated  Renntec engine bars might be perfect.  We'll know when they become available.  Are the FJOC engine bars comparable in build and quality?  Let's wait to see how the re-powdered Renntec's look.
Insofar as shipping goes, I recently purchased motorcycle parts from BikerMart in the UK and they used UPS and Parcel2Go for shipping.  The shipment went very smoothly.
I appreciate your help!
Hi Steve, the engine bars that the FJOC sell are Renntec, so are brilliant  :good2:
I'll see my pal Chris over the weekend and see if we can get a slot to do some powder coating any time soon.
STLanduyt
Over the past week I have been attempting to remove (for the first time) the upper fairing on my 1985 FJ1100.  I read all the fairing removal posts and owe a huge debt of gratitude to oldktmdude
and FJ1100mjk for their posts.
oldktmdude in 2013 wrote, "with all due respect to the others that have commented on fairing removal, disregard everything they have said. They are talking about removing a fairing from later model bikes, not an '84 or '85 which are totally different."
FJ1100mjk in his 2015 post gave a step-by-step tutorial on removal of the fairing on an 84/85 FJ.  Step 7b details how to detach the fairing from two small "pins" located on both sides of the frame adjacent to the oil cooler.  That was exactly where I had been hung up, but I couldn't see the pins and the 1984 Yamaha Shop Manual I am using doesn't show or even mention them.  Once I read FJ1100mjk's post and successfully completed step 7b, VOILA! ... removal of the fairing was straight forward.
Thank you.
STLanduyt
This is an effort to post a few photos of the current state of my FJ project.  (If the photos do not appear, I am sorry but I tried.)
The removal of the upper fairing has revealed years of road dirt and small areas of rusty on the main frame and subframe.  The fairing itself is in great shape, but very dusty on the inside
The immediate plan is to clean the entire  frame, respray the front and rear subframes black and respray the main frame silver after the wiring has been removed and the rusty spots are de-rusted.  Hopefully it is only surface rust. The rear frame also has a bit of rust ... mainly around the welds, so those will need de-rusting and respraying.
The available work area in the garage is small.
"C:\Users\stlan\OneDrive\Desktop\recent photos\front.jpg"
"C:\Users\stlan\OneDrive\Desktop\recent photos\front subframe.jpg"
"C:\Users\stlan\OneDrive\Desktop\recent photos\overhead.jpg"
"C:\Users\stlan\OneDrive\Desktop\recent photos\side.jpg"
STLanduyt
You cannot view this attachment.You cannot view this attachment.
Not great photos, but hopefully you can see the current state of my 1985 FJ1100.  It has been garaged and car-ported in San Diego since leaving the Yamaha dealer here, but is in need of restoration, nevertheless, as you can see.
It is gradually being disassembled, cleaned up, de-rusted, spot painted, updated with a fuel pump, RPM refurbished carbs, new tires, new clutch/brake hoses, chain, etc., etc.
The fairing is in great shape ... just needs cleaning.  The engine  only has about 5,000 miles on it (I only rode it on weekends), which may be unusually low.   It currently awaits the carbs and a new  battery, and the rest of the restoration before being restarted.  I appreciate the advice that I have received (and hopefully will continue to receive) from members about the care that should be taken before restarting the engine, as well as other suggestions to make the FJ "friendly" to a now "older" rider.
86FJNJ
My 1200 sat 15 years, before starting I changed the oil,  i took the valve cover off and put assembly lube on the cams and cam chain and put the valve cover back on. Be careful not to over tighten the valve cover bolts, just tighten them until they stop, no more, very light pressure or you'll strip them out, I removed spark plugs and sprayed oil in the spark plug hole and let it sit for a few days, then turned the engine over without the spark plugs installed so the oil was pushed out ( put a towel on top of the engine because the oil will shoot out). Then I put spark plugs back in and started it.
STLanduyt
Thanks 86FJNJ for the pre-start list of essential things to do before cranking the engine after a prolonged hiatus i.e., decades not merely years.  I won't be ready to give the engine a try for awhile since the carbs are off, so is the tank, and I don't have a battery yet.  In the meantime, and now that the front fairing has been removed, I am cleaning up the front end, will remove the forks, take care of the rust, and repaint areas that need it, which is primarily the front frame (the silver/gray frame).
What available spray paint (rattle can) has been found the best match for the early FJ's?
STLanduyt
Thank you Pat.  The local auto paint store had VHT Ford Argent Silver in stock.
At this point painting the frame is a few days away, as the rubber hoses and wires in the front are still being removed or pulled out of harm's way.
Are there any special techniques or things to watch out for in dealing with the oil cooler?
Drain your oil.
Remove the oil cooler lines via the 2 fittings on the oil pan. Leave the lines connected to the oil cooler and to the pan fittings.  After you remove the (2) allen screws at each pan fitting, the fitting pulls straight out, towards the front.
You will see an O ring on each fitting where it seals to the pan....plan on replacing each o ring.
 If you can't find these o rings locally, Call Robert at RPM, he will take care of you.
STLanduyt
The FJ1100 project is well underway.
Using a combination of a small "block and tackle" type pully system and load bearing Husky brand straps, the FJ is suspended off the ground in the garage so that the wheels can be removed and re-tired.  Also while it is in "suspended animation" the front fork will be removed and refreshed; the front sub-frame, which has been stripped to bare metal and de-rusted, will be repainted, as will the front end of the main (silver) frame; and, the rest of the silver frame and the rear black frame will be spot de-rusted and painted.
There is a bit of wiring that needs to be replaced, and I will add the plastic wire "sleeves" to cover the wires (mainly to the rear blinkers) that don't have them.
In short, there are still a ton of things to do to get the FJ ready to receive the rebuilt carbs from RPM, install the fuel pump, and follow all of the good advice I have received before starting the long-dormant engine.
Quote from: STLanduyt on February 01, 2026, 02:43:58 PMThe FJ1100 project is well underway.
Steve,
Not sure what you are calling "sleeves," but this is cable split-wrap, available at auto parts stores (and even WalMart). You can install it easily on existing wire bundles, without disconnecting any wires. I would secure it, compressed to fit the wiring, with tiny TyWraps along the way.
Split Cable Sheathing
HTH.
STLanduyt
Thanks Red ... we are referring to the same item ... a protective covering for wires.  Yamaha has a lot of wire protection, particularly around the engine, but in the back some of the wires that run under the seat have no protection beyond their colored plastic covering and are showing some wear spots.
Steve,
The auto parts stores should have Liquid Insulation for wires in cans or bottles. You may be able to find various colors. Color aside, just separate the wires in the bundle, paint on the new insulation as needed, and let dry. That plus the sheathing should protect the wires very well.
