oil sensor replacement
Started by filsurs, November 12, 2025, 11:45:31 AM
filsurs
 :blush: since today, my oil sensor doesn't work. I don't get a Light whith a cold start while the light will work together with the ABS light when testing. Is replacement of the sensor difficult? Thxs 4 helping
RPM - Robert
The light is a float. It should only come on when the oil is low not when it is cold.
That said it is easy to replace with teh exhaust removed.
filsurs
Quote from: RPM - Robert on November 12, 2025, 12:16:14 PMThe light is a float. It should only come on when the oil is low not when it is cold.
Thxs, If I understand you correctly, it doesn't light up if u turn the ignition ON?
RPM - Robert
It may do that. Our bikes are in storage so I can't check but it shouldn't come on because the oil is cold.
filsurs
Quote from: RPM - Robert on November 12, 2025, 01:48:36 PMIt may do that. Our bikes are in storage so I can't check but it shouldn't come on because the oil is cold.
Thxs
Is it the sensor or bulb?
There is an oil light and fuel light check function that the owners handbook outlines. .
1) turn the handlebar run/stop switch to stop position
2) turn on the key ignition switch
3) press starter button.
Both the oil level light and fuel level light should illuminate on the gauge cluster.
Failure of either light to illuminate indicates a burned out bulb.
filsurs
Quote from: Pat Conlon on November 12, 2025, 03:18:13 PMIs it the sensor or bulb?
Correct, the ABS and Oil light are werking...the fuel Light doesn't. If I understand it correctly,  the oil light is just for OILLEVEL not PRESSURE? That would explains why it isn't werking like other bikes/Carson do.
Correct, it is an oil level light...thankfully not oil pressure.
Very common to have it blink on during hard acceleration.
We call it the kookaloo light.
filsurs
Quote from: Pat Conlon on November 12, 2025, 05:22:33 PMCorrect, it is an oil level light...thankfully not oil pressure.
:mocking: nice thxs very much !!!!
