High compression pistons
Started by crazy88, November 07, 2025, 07:17:58 PM
crazy88
So I have a set of weisco 12:1 pistons. I pretty much know the answer but just gonna ask anyways. Can the stock rods handle that high of compression? If not the stock ones, how about the xjr1250 rods that RPM has listed. Also from what I understand, with raising compression I should consider a programmable CDI to retard ignition timing. Is dyna2000 the only option (if not a recommendation would be greatly appreciated) and are they any good. Because I've seen very mixed reviews regarding them. Any insight would be greatly appreciated.
Crazy88,
I would sell off those pistons, personally. The FJ is aged, and extra horsepower now could put too much stress on the old power train components. High compression requires high octane fuel, and if you are avoiding ethanol now, you might have to buy Avgas from the airports or the hotrod crew, which will probably include lead additives. The carbs may need new jets. For your fine FJ, I would simply say "If it ain't broke, don't fix it." YMMV.
crazy88
Yea I'm kinda leaning that way tbh. I kinda bought them hastily off eBay cuz I thought they were a good price but didn't really do the research before hand. I've gone way over budget with my rebuild and I am probably gonna have to sink $500 on new valves yet. So I might just forgo the weiscos. Idk if I would be able to sell the pistons again because I already gapped the rings to my cylinders. That being the case would I possibly be able to use the weisco 77mm rings on the stock pistons?
Crazy88,
Don't know about the ring thing. Can you get new rings from Weisco, for the resale?
As for valves, it seems like you can get a good used head, complete, for less money.  I would expect to lap in a few valves, maybe all, but still come out with less expense. You would probably need some new shims, though. RPM may have some help for you, for a good cylinder head.  They know people in the game.
  :yes:
crazy88
I agree that's probably the most cost effective route. I found an 1100 head on eBay that looks in great shape for just under $300. Probably gonna go that way. Thanks for the input brother.
I agree with Red, sell those 12-1  Wiseco's.
On buying a used head I would plan on *at least* surfacing the gasket surface, installing new Viton valve seals and assuming the valves and seats are healthy, lapping the valves.
http://www.rpmracingca.com/proddetail.asp?prod=Head%3AVSS&cat=39
Beware on used FJ heads.
It's common to have leaky exhaust valves and/or valve seats due to tight valves from deferred maintenance.
If the head was overheated you may also need to line bore the cam journals.
crazy88
Yeeeea. Already have the valve seals cuz that was the whole reason I started the re build. Every single one was leaking a ton. And one of cylinder 3 valves wasn't sealing anymore. Now none of my valves are sealing except the exhaust ones on cyl 3....I believe I over lapped them. But yes that is my main concern in buying a used head, that the valves are gonna be fucked anyways. And the fact that I already had a hell of a time surfacing the original head , I really don't wanna mess with all that again. Might be my only choice tho lol.
RPM - Robert
You can send the pistons to us and we can cut the dome down in our piston vise to lower the compression and you will still be able to run them. I'm not at the shop today but I have new Yamaha intake and exhaust valves in stock. I don't have them up on the website but I could get you a price tomorrow.
Well, there you go...14 years ago Randy and Robert shaved off the dome off my 83mm Ross pistons. Dropped the compression down from 12-1 to 10.5-1 much more friendly for the Calif piss water pump gas. They also balanced them to 0.2 grams dead nuts.
RPM - Robert
Current Yamaha price on the valves is $34 for both intake and exhaust. I can do $20 ea.
crazy88
Quote from: RPM - Robert on November 11, 2025, 10:10:10 AMCurrent Yamaha price on the valves is $34 for both intake and exhaust. I can do $20 ea.
Hey Robert
How much am I looking at for y'all to shave the pistons? And I need all 8 exhaust and 7 intake. I already got 1 intake from you guys just to test to see if I could lap it probably and it seal in hopes I didn't mess the seats up. But you can do all 15 for 300?
RPM - Robert
Yes, the valves for $300 the prices seem to be fluctuating recently but $20 ea is what we got them listed as now.
Probably $150-200 to cut the pistons been a few years since I did any but it takes a couple hours setting each piston up and making passes.
crazy88
Quote from: RPM - Robert on November 11, 2025, 02:25:22 PMYes, the valves for $300 the prices seem to be fluctuating recently but $20 ea is what we got them listed as now.
Robert,
I'm gonna get the valves ordered up Friday when I get paid. How do we go about payment for the pistons, I can get them shipped out next week.
RPM - Robert
We can do a credit card over the phone or PayPal.
