Factory header tubes
Started by captaudi, July 21, 2025, 04:40:53 PM
captaudi
Collective,
So stupidly I tossed my complete factory 93 exhaust over 15 years ago. I am now assembling the parts to replicate aviationfred's system of factory header pipes, factory style (he used an english made XJR part) collector and Dominator mufflers. This will allow me to finally mount the complete Krauser K2 system that I have owned for 15 years. I bought a set of factory double walled (early?) header tubes and a perfect factory collector from my favorite used parts emporium. Pat mentioned to be careful cleaning the early tubes as the black chrome will come off. They are caked in very old bugs. Best cleaner? Second, being as they are double walled is the ID smaller and thus a restriction? I had put a post up looking for the later pipes and had no offers, these were too good to pass up dollar wise. If the later pipes perform better I can watch over time for a set. Next year after child support ends I am going 1350/1380 (not sure yet), I want to let the big pump breathe.
So thoughts on cleaning and performance of early pipes?
Daniel
93 FJ1200 FZR1000 wheels, Vance and Hines SS2R, Hank Scott jets R1 Monoblocks. Cartridge forks in the works.
1985 RZ350 couple mods
1977 R100S restoration in process
1972 Porsche 914 for days I feel like being left stranded.
86FJNJ
Can't answer you questions but curious what year FJ's were double wall
captaudi
It sounds like the 1100 was the double walled. Possible early 1200 as well.
86FJNJ
I'm also curious what those little bings are for at the bottom of each header tube....some kind of air fuel ratio check port?
Quote from: 86FJNJ on July 21, 2025, 05:06:18 PMI'm also curious what those little bings are for at the bottom of each header tube....some kind of air fuel ratio check port?
Exactly Eric...The factory used those ports to dial in the air/fuel idle mixture, then they put tamper proof caps over the adjustment screws....so knuckle heads (like us) couldn't fiddle with them. Silly bureaucrats.
Daniel, yes, the double walled tubes were oem on the '84/85 1100's
In '86 with the 1200's they went to single walled stainless steel tubes.
At the time, the double wall tubes were considered a performance enhancement, keeping heat within the gas flow to help scavenging, much the same way wrapping the header tubes do today. I know the OD of the double wall tube is larger than the single wall stainless tubes....I don't know about the ID of the double walled tubes.
I do know they sound like Armageddon when the inner tube cracks and flails itself against the outer tube. Clang, clang, clang, clang, clang, clang, 800 miles of clang, clang, clang, clang, clang.
I scratched my 84's black chrome tubes by soaking the bugs then (I thought very gently) using a green scotch bright pad. Dumb mistake.  I should have stayed with my trusty Simichrome and a soft cloth rag.  There is a fine abrasive in the Semichrome, it just takes patience and elbow grease.
With all my polished aluminum, I buy a lot of this stuff
Now that I have converted to stainless, any scratches or stains I can aggressively rub out...or take them off and use my 1hp buffer.
Cheers.
Motofun
I had my '85 exhaust headers Jet Hot coated.  They sand blasted them prior to putting the ceramic coating on.  Apparently it was just enough to weaken the weld between the inner and outer tubes.  Shortly thereafter, when at the rally in Tellico, the weld gave up the ghost.  I thought for sure I had a rod gone south but the damn thing ran anyways!  What to do?  RUN IT, what else could happen?  Anybody need a beautiful set of stock '85 pipes that are jet hot coated?  Impress your friends with how stout your bike is that it can run with a broken conrod.    :wacko1:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
captaudi
Pat,
I know Simichrome all too well. We had a family friend that had a collection of Stanley Steamer brass cars. I used to ride my bike to his house during the summer, I had a key to the garage. I would spend 2-3 8hr days a week polishing all of the brass. My fingers were black for a month. Do you know the shoelace trick? get a coating of polish on the tube then wrap a shoelace around and pull it back and forth. The good old days!
Daniel
86FJNJ
Can the stock transmission handle 1350/1380?
RPM - Robert
86FJNJ
Ok I see people posting that and selling bikes where 2nd gear is shot or the fork shifter broke so that was why I asked. The FJ is a great engine then, so is the Yamaha CP3 engine considered the modern version of the FJ engine in terms of versatility and reliability?
RPM - Robert
The early shift forks were shorter and would bend. This would damage the transmission engagement cogs and windows. Which in turn would cause it to come out of gear and get worse over time. Doesn't matter if 1100cc or 1380cc
I don't know anything about the CP3
