Oil Nozzle OK... What else causes low rpm rattly sounds?
Started by 3XW_LOGIC, July 13, 2025, 09:37:58 AM
3XW_LOGIC
So my 3XW was making a garagarakarakara sound on low rpms which led me to doubt the oil nozzle on the starter as suggested by some previous experiences here and on the xjr forums...
Have adjusted my idling to 1200rpm and I don't hear that sound often
But, for mental safety, Took out the nozzle and found it in pristine condition
No rubbing of the chain on this so far. Some minute manufacturing scratches that can be seen aren't by the chain (different angle)
So...
What else could cause a sound that I can best describe as "garragarr" when the idling is set below 1100RPM or when I'm halfclutching slowly from a stop without revving up much?
Next thing I'm gonna try is to see some other parts suchas the starter one way clutch
 (seems fine though, as when I drive the engine backwards by using the nut on the spark timing pickup side it rotates the starter, but the engine moves smoothly immediately disengaging the starter clutch when moving in the normal direction.)
Well then I tell myself, I'll just live with it... But it bothers me to not know.
I've new cam chain tensioner and guides installed and that didn't change anything.
I also took the clutch out to see if the damping springs behind it were bad, but they seem solid, nothing jittery there.
I'm in the process of checking valve clearances and I have discovered almost all valves clearances are in spec or at most 0.01mm on the loose side..
(on a cold engine, overnight)
Still, im going to do the shims and see if it makes any difference. Then do some carb balancing...
Next I'll try to see if there's some other parts that can potentially cause a rickety rattly feeling at low rpms (I really don't want to open/split the case as a longrride is coming up though)
Any suggestions on what else i can look at (without splitting the case?)
(ready to live with it, but just trying to do some safe easy investigation into this issue)
Abhi
Mori/Iwata/Shizuoka
Japan
Well now that's a puzzle....how many miles are on your engine?
Our starter chains stretch, just a fact of life.
Could you be hearing a clutch plate chatter?
Did you remove the wire snap ring and cushioning spring from your clutch pack so you could convert over to a 7 wide clutch plate set up?
Is the clutch basket secure? No wobble or run out?
Try removing your cam chain tensioner, inspect it, make sure the compression spring has full range of easy motion, if ok, reset it and reinstall it.
That's all I can think of...
Pat
3XW_LOGIC
Thanks Pat
I'll go through the suggested Clutch and tensioner checka later this week one by one and post an update.
To answer your question, I have about 55000 km on the bike (which to me is quite young in my opinion).
And it's in superb condition.
When I had taken the  head off a year ago to change the head gasket and rubber thing as there was a tiny oil seep on the exhaust header side, and the cylinders were all beautiful clean, no scratches, honing marks still visible, the cams are super beautiful too (the previous owner was definitely changing the oil often and driving well before somehow being abandoned for a year or two).
It's like a rocket and has the full power. Plugs were beautiful too. Responds well to all (normal and crazy) driving inputs.
I have a new tensioner, nice fresh tensioner mushroom head, and new spring, maybe I'll try pushing one click more? Is that recommended. If may have messed it up while installing it initially. I installed in its shortest condition and then added the spring from behind. Maybe I'll add it in the shortest condition, use some tool to click a notch, and then add the spring. Not sure whether this is right but some others seem to have done this before.
About the clutch, no I still have that pesky wire thing and the narrower clutch plates and springs. I guess I'll get rid of those and put full size ones on.
The friction plates are thick still and have plenty of life in them though..
Next im going to look at the accessories parts near or on the engine, like the generator, the starter motor, etc. That rotare with the engine. I have an XJR1200 too so maybe try interchange parts to narrow down possibilities.
Is the generator known to get rattly? Does the engine run without the generator in place? For testing only of course (Or does oil start spewing out crazy ...) same thing with the starter motor - maybe I'll somehow start the bike and the pull the starter motor out haha. (probably not recommended)
Although I'm beginning to think It could simply be the carburettor not properly in sync at idle. It purrs like a cat at 1200 but still, I've anyway ordered adjust shims and so I'll do a carb retune after i do the valve clearance adjustments.
I had a nightmare that some part of my chassis is cracked and is making that sound. Was scared and checked the chassis in the morning, obviously nothing wrong with it (at least in all the visible parts) lol
Hope I get to pin the issue down soon....
Happy Riding!!!
Abhi
Mori/Iwata/Shizuoka
Japan
T Legg
If your carbs are out Synchronizing them can make a big difference . I put a new motor in recently and it ran great from 1/4 throttle on up but at idle and low rpms I could hear a regular rpm related thumping noise and feel the vibration or Harley like shake. It was much better when the clutch was disengaged and the transmission stopped spinning in nuetral. I swapped the entire clutch assembly with one from another of my bikes with no change in sound or vibration.
 By then I thought it must be the transmission. Before I was going to do anything drastic I decided to check the compression, recheck the valves and balance the carbs.
 I was surprised the sound and vibration dissappeared compietely. Now my bike runs strong and smooth from first cracking the throttle to w/o throttle.
 I adjusted the valves last in the winter and wether due to the heat or sloppy adjustment the last time, I had several  tight valves . I think what really solved the problem though was the carb synch . Carb #2 was way out of synch .
T Legg
3XW_LOGIC
Quote from: T Legg on July 14, 2025, 01:53:47 AMIf your carbs are out Synchronizing them can make a big difference . I put a new motor in recently and it ran great from 1/4 throttle on up but at idle and low rpms I could hear a regular rpm related thumping noise and feel the vibration or Harley like shake. It was much better when the clutch was disengaged and the transmission stopped spinning in nuetral. I swapped the entire clutch assembly with one from another of my bikes with no change in sound or vibration.
Thanks for sharing this.
This gives me more reason and hope.
I'll do a proper carb sync and post an update!!! (as soon as my shims arrive coming week)
Abhi
Mori/Iwata/Shizuoka
Japan
Perhaps when you reinstalled the head you mis installed the cam chain tensioner?
https://fjowners.com/index.php?topic=5620.0
If the growling sound you hear is chain related, there are only 2 chains in the FJ engine and we know the starter chain isn't the issue.
3XW_LOGIC
Small update:
Made an excel to calculate the shims last week, figured I had to order only 2 shims of size 270 and shuffle the others around to get "good enough" valve clearances. Yay!!! this went cheaper than expected. 6 valves adjusted 2 shims purchased. :morning1:
Now all my valves are "in spec or just a teeny bit on the loose side"
EX, IN counting left to right as seen on the engine. (attached image) Red crosses on graph denote pre adjustment valve clearances, yellow dots show after adjustment (calculation). Did a go-no-go kind of test afterwards (as some here said that immediately after shim change, reading is off)
Forgive me as this now goes off-topic,
And while I was waiting for the shims to arrive, I removed the rear suspension, cleaned and greased everything up and put it all back together - found that getting the bolt off from the suspension top mount requires you to move the air box, which is quite a pain.
Also discovered that the under-tank fuel hoses were getting a bit old and hard, so in the process of changing them. Original hoses unavailable, so got some 90degree bends and will now work on routing a flexible hose around there. People with experience may give some advice on routing hoses. The hose from the filter to the pump is 6mm on one side and 8mm on the fuel pump side. Great. Now i need a 6mm to 8mm nipple and a short piece of 8mm hose. meh.
I will post an update about those other things in another maintenance topic later. Interesting things learned.
Abhi
Mori/Iwata/Shizuoka
Japan
3XW_LOGIC
UPDATE: some improvement but not 100% gone
After changing the valve shims, doing a carb cleaning up, the "ticky" sounds have reduced, but the "garagara" sounds at rpms lower than 1100 haven't COMPLETELY gone.
 I rechecked the cam chain tensioner, reinstalled it, both inner and outer springs in there, (quite a hard job to get them in place and put the bolt on ) doesn't seem to change the sound much. Reduced a bit though after the valve clearance adjust shim change and rough carb balance (with a single guage).
So conclusion = I am going to "JUST LIVE WITH IT" (whilst keeping an eye and ear open and hope nothing breaks)
I'll do a carb balance with 4 vaccum guages later and see how it goes later, as i feel the sound is definitely worse if the torsional vibrations exist, and is definitely on the left side of the engine.
Some other things come into mind though,
Could as well be piston slap?
Could there be looseness in some conrod pins?
Could it be the starter one way clutch thats engaging and disengaging at a particular temperature?
Has some loose object fallen inside (oh the horror)
In which case a spare engine will be in order...
I'll try to keep these thoughts aside at the moment and enjoy the ride as she rides well anyway.
Thanks everyone for advice and suggestions. I'll post update here with found solutions or improvements
Abhi
Mori/Iwata/Shizuoka
Japan
Old Rider
The  rattle that comes when taking off can also be from strethched starterchain and worn starterchain damper. Se pick 17 from top  page 4 in this tread https://fjowners.com/index.php?topic=18143.45.
If you have found some black plastic strips in oil it is from a camchain or starterchain slider/damper
3XW_LOGIC
Quote from: Old Rider on July 24, 2025, 01:50:20 PMThe  rattle that comes when taking off can also be from strethched starterchain and worn starterchain damper. Se pick 17 from top  page 4 in this tread https://fjowners.com/index.php?topic=18143.45.
I haven't found black debris in the oil, but that may be because most of the black plastic was taken away during the use of the previous owners use and regular oil changes.
As I see it it's not an immediate risk to safety, so I'll go do this long journey I have to do (about 4000km) and then I'll drop the engine and split the cases and inspect every nook and corner.
Wonderful details on your post, very informative. As I'll open my cases in September, those posts will be definitely of good reference.
I understand that without splitting the case, much isn't possible to do about the starter chain and damper yes?
Will taking off the oil pan whilst the engine is on the bike allow me to inspect the said components (hope)
Thanks!!
Abhi
Mori/Iwata/Shizuoka
Japan
3XW_LOGIC
Update:
The ticky sounds reduced, I continued working on the bike.
Cleaning the carb and putting some high density and high temperature resistant silicone grease to the intake manifold o rings, carburettor joints, rtx After sealing some possible?? secondary air, then,
With a proper 4 vacuum guage set with passage orifice damper taking a good carb balance/ synch (got myself one!)
After setting all four idle fuel screws (pilot jets) to 2.5 turns out,
And setting the RPM just above 1200, has "almost" completely got rid of any gargling sounds.
And with the brand new tires, 18-38 sprockets, DID VX3 chain, and new oil and filters, the bike is now ready for the long journey!
Now building myself a "full-pannier". Will make a post somewhere soon.
Thanks all for the advice that has helped me get the sounds to acceptable and non threat levels. Happy riding!!
Abhi
Mori/Iwata/Shizuoka
Japan
81Delorean
Quote from: 3XW_LOGIC on July 27, 2025, 11:04:33 AMUpdate:
Sounds like you and I were kind of doing the same things. I got my carbs rebuilt, cleaned, new jets, synch'd, seems to be running good now. Voltage regulator mod done, sprockets changed to 18/38, still need to change the oil/filter before my trip but I think I'm about ready. A little nervous because of the age of the bike, me not having it long and hardly any miles put on it by me but it's a Yamaha and bulletproof so we'll see how it goes. I would like to see what you do about panniers. I bought a small cheap set that fit ok, don't hold a ton but I don't carry much so I think it will be ok. I carry most stuff in a 70L duffle on the back.
Jason
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
Old Rider
Sorry for late reply !  to be honest i dont know if you can see the starterchain damper after removing the oilpan.I dont remember  One thing you can do that i think you will be able can check the condition of the damper is to get a borescopecamera With a twistable tip. I bought this one cheap from china,so far it has worked great for many things. You can inspect the valves and many other things with it.
As for the starterchain noise i would not worry and just ride.The damper is most likely hard as stone and worn so it makes some extra noise.
3XW_LOGIC
Quote from: 81Delorean on July 27, 2025, 11:33:50 AM
The ticky sounds reduced ...... .... non threat levels. Happy riding!!
Jason
Jason, I wish you a trouble free and super fun journey!!
I'll post about the pannier soon. Almost done with them. Some top case, some modified side carrier from Givi etc. I've not done the voltage regulator yet but i have a week so maybe i can squeeze that mod in this week. My brake lamps etc don't last too long maybe has something to do with it.
Quote from: Old Rider on July 27, 2025, 03:35:09 PMSorry for late reply !  to be honest i dont know if you can see the starterchain damper after removing the oilpan.I dont remember  One thing you can do that i think you will be able can check the condition of the damper is to get a borescopecamera With a twistable tip. I bought this one cheap from china,so far it has worked great for many things. You can inspect the valves and many other things with it.
Thanks for the suggestion , Old Rider
A scope!! That's something i should add to my toolbox. I'm a bit wary of cheap Chinese stuff, but my pockets aren't so deep, and I've just spent a lot on proper Japanese company vacuum gage, proper chain tool, chain, sprockets, tires, etc haha
I'll get a proper scope and  check the insides as soon as my wallet is slightly full again. :flag_of_truce:
Any suggestions on the scope brand etc?
Abhi
Mori/Iwata/Shizuoka
Japan
Old Rider
I have 2usb scope that also was very cheep,but to take a look up at the valves i had to make some mods. I bought this camera because it has that twistable or articulating tip ? sorry bad english  and it was so cheep that it did not matter if it was useless. I think i paid 30 or 40 usd cant find the link now.I have seen them
for 1800 usd to,but for my need that was only to check the bores and valves oil picup screen ets on the kawasaki kz900 that i rebuildt last year it works great.
i dodt have good picks taken with the camera on this pc but have these from the kawasaki engine after it has runned about 3000miles.
Another thing that can make rattle sound when standing still is the clutch basket or
the needlebearing .Does the rattle go away if you pull the clutch lever? if it does it is maybe worn basket so the clutch plates rattle inside the basket .
And almost forgot - i wish you a nice journey !  :good2:
You cannot view this attachment.
You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
