Clutch pull force
Started by captaudi, July 09, 2025, 06:29:52 PM
captaudi
In case any of were wondering. Barnett conversion, gold springs, FJR 14mm master = 19.2lbs max measured center of the lever.
I like numbers.
Cheers.
93 FJ1200 FZR1000 wheels, Vance and Hines SS2R, Hank Scott jets R1 Monoblocks. Cartridge forks in the works.
1985 RZ350 couple mods
JMR
What year FJR master did you use?
captaudi
The eBay auction listed it as 2006-2012. It is a 14 mm master.
JMR
captaudi
Mike,
I'm not sure if you remember me. You loaned me your shim kit about 15 years ago, I lived in Shrewsbury at the time. You basement was like a candy store devoted to CB750 heads. Is Dana Johnson still doing heads? I am hoping to do the FJ motor next winter and he would have been my first choice for the valve/guide work.
Hope you are doing well.
Daniel
JMR
Daniel....I do remember that now that you mention it.That's funny. I now live in New Hampshire in the Lakes Region (Moultonborough). ...just north of Weirs Beach. Yeah...I still have and do a lot of CB750 heads. :yes: My last big project was rebuilding the engines for the RC Engineering Triple dragster. Actually I didn't rebuild them I had to reengineer them starting with 3 fresh engines. God the original engines were terrible.
 Dana finished his house in Maine but I'm not sure if he is doing work there. I don't think he sold the house in Hopkinson where all the machines were. If you need guide and valve work....and maybe a sprinkle of porting.....I can certainly help you out.
 Thanks for the FJR master info. I was going to go with the 14mm pee cup but I like the stock looking unit and there are no clearance issues.
captaudi
Mike,
Congrats on the move. Where did Dana build a house? I am in Harpswell ME about 20 minutes further up the coast from Freeport. The only thing I have not yet sorted on the master swap is the clutch switch, the FJ is a 2 pin the FJR is 3 and it does not swap over. So you can't start the bike in gear. Looks like Yamaha does not service the pin housing separately for the FJR, I was hoping to swap my pins into a FJR housing. I can tell you the setup I have is sweet to ride in traffic, with your motor you might need to swap for heavier springs or do the 3 and 3 trick, thats what I did in my RZ421.
Daniel
