Header Temps
Started by 81Delorean, April 13, 2025, 08:53:52 AM
FJ1200W
I'm a fan of pulling the carbs and doing it right.
With practice, the carbs can be removed and replaced in an hour, it's pretty simple.
Add another hour to clean and blow the passages, a quick clean, and if that looks good, you're done in 4-6 hours unless you are really good.
Double those times if you want to truly do a deep clean.
NGK Standard plugs, always.
Columbia, Missouri
USA
81Delorean
New plugs in, mixture screws set correctly, carbs synched, it is running and idling much better. No more pops/backfires. I have yet to actually go for a ride on it but given what I've encountered so far by the PO's, I will still end up getting 4 rebuild kits, pulling the carbs and giving them a nice ultrasonic bath and then running brushes through the passages, shooting some carb cleaner through them, blowing air through them and then maybe another ultrasonic bath/air before going back together. I wish my ultrasonic cleaner was big enough for all 4 carbs to fit at one time. Thanks for all the help and advice so far. Input is always welcome. Hope you all are having a great weekend.
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
81Delorean
Carb rebuild kits as well as the screw and O-ring kit ordered from RPM last night. Sounds like I will have a weekend project coming up pretty soon.
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
Try and use an ultrasound bath for cleaning...
81Delorean
I'm going to. My plan was to separate the carbs, disassemble, soak them for a little while, run brushes through the passages, put it in the ultrasonic cleaner, run brushes again, another ultrasonic, compressed air and reassemble. Maybe overkill but why not?
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
As long as you are not reaming out passages or jets - there is no such thing as overkill when cleaning carbs gunked up  with todays gas!
81Delorean
Quote from: fj1289 on May 01, 2025, 12:34:46 PMAs long as you are not reaming out passages or jets - there is no such thing as overkill when cleaning carbs gunked up  with todays gas!
All the holes and passages seem so small. I was going to drill them out bigger so they won't get clogged so easily! :lol:
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
81Delorean
My carb kits should be here tomorrow, I pulled the carbs off today and dismantled each one. Have the first one soaking right now. I don't know how people are posting pics on here, I don't see the option but I would love to show off how it looked on the #3 carb, no wonder there were problems.
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
81Delorean
I've got the carbs all cleaned and rebuilt with the exception of one of them. When I disassembled them, one carb was missing the main jet needle plastic retainer, I didn't notice that the rebuild kits didn't come with new ones. Sent an email to RPM and he is going to look tomorrow to see if he has one sitting around. If not, I guess I'm going to have to find a cheap jet needle set just for that one part unless someone on here has an extra they are willing to part with.
Other than that, and being pretty gunked up, everything went pretty smooth. My first time setting float height, I have a float gauge, read a lot on the procedure, didn't seem that complicated. Can't wait to see how it runs now.
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
