Does rear wheel have 3 bearings?
Started by 86FJNJ, April 12, 2025, 04:45:26 PM
Motofun
I have a couple of brass drifts that I use to remove old bearings.  Since the bearing is going to be trashed anyways I don't see the problem.  I do have a Park bearing removal tool for steering head bearings.  If I did this job often I would have various sizes of the Park tool.
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
Any play between the bearings and spacer will go to zero when you tighten the axle nut. This way all the seeming loose parts and up acting like a solid axle for the rear wheel. All the wile, the bearings are not pinched or bound and roll freely.
That said, when you reinstall, the spacer might have a little play till you torque the axle nut.
Jpn
I used a harbor freight bearing puller for removal which worked good. Tool has expanding mandrel with a small lip to catch the inside edge of the bearing. As for installation, the freezer treatment and socket as a driver got em back in.
Cherished 1985 FJ 1100
