Bar weight installation
Started by n8man1068, March 09, 2009, 08:08:46 AM
n8man1068
Many thanks to Troy for the weights.
I had twisted/screwed in the throttle side weight this morning, but it must've been too tight since I couldn't rotate the throttle. I backed it off a bit and everything was fine. Started my 13mile commute to work, and at some point looked down and noticed it was gone. gawdamnit.
So is there a trick? Should it just need to be screwed in? Lock-tite the hell out of it? I'm going to go back and scan the roads after work to hope by chance that it is just sitting on the side of the road.
Factory Pro Stage 1 kit
Vance and Hines SS2-R
RaceTech fork springs
Corbin Gunfighter and Lady seat
'86 FJ1200 gas tank
gradice
Quote from: n8man1068 on March 09, 2009, 08:08:46 AM
You may have to trim your grips down a bit, I've never had a problem with my ends droping off ;) or you can try the Lock-Tite thingy trick!!!!!
Graham in OZ...
92 FJ1200 ABS.
n8man1068
Trim the rubber, or the tube itself?
'86 FJ1200 gas tank
the fan
Whichever is making contact with the bar end.
Yamifj1200
Dude,
  You can move the rubber grip around a bit on the throttle tube with an air compressor and an air nozzle.
The bar ends screw in until tight and you dont need Lock-tite to secure the bar end weight. I have never had any problems with the throttle dragging on the bar end weight. Are you using the stock rubber grips or aftermarket ones? Note to self, never leave any fastener on your bike loose for any reason including bar ends...
Eric M
n8man1068
Cruised my route a few times, couldn't find the errant weight. Rather ticked at myself.
After trimming the grips, which I assume are stock, the weight is hitting the throttle tube. I assume the grips are stock as I myself have never replaced them, but I have no clue of the bikes previous 2x year history. There are no other fj's in my area that I can compare my grips to.
What are my options if they are hitting the tube itself? I'm leary about grinding tube. Maybe loosen the right side switch block and see if I can scoot it over, and the grip with it? If it makes any difference in determining why it is hitting, the throttle tube is white and feel plasticy. Saying this because I usually see black ones on ebay.
'86 FJ1200 gas tank
Yamifj1200
"What are my options if they are hitting the tube itself? I'm leary about grinding tube. Maybe loosen the right side switch block and see if I can scoot it over, and the grip with it?
I'm sure you don't need to grind the throttle tube for the bar end to be installed properly. Simply slide your switch assembly and throttle housing in on the bar as far as you can. I bet you can install the bar end then with no problems, ah but you still have a problem right??? No Bar end.... I happen to know there is an FJ owner in the Richmond area with a old spare bar end.
Eric M
n8man1068
Luckily, I was sent a set of ends, so I have a spare.  :D
I'll keep my eye out for the white pickup that was behind me this morning...maybe I'll see the weight in his grill? lol
'86 FJ1200 gas tank
If your bar weight is hitting the grip, and you don't want to move all the stuff on the bar, you can put a 'stand-off' washer between the handlebar and the bar end.  This will keep the bar end weight a bit further out.
TRoy
I guess it's the correct bar end, came off an 86...  :P
Peace & Love
86FJ 100K+
07Burg650
15Downtown300
rlucas
*If* you end up having to trim the throttle tube itself, DO NOT REMOVE ANY MORE MATERIAL THAN IS ABSOLUTELY NECESSARY FOR CLEARANCE.
Due to a completely dumbass attempted mod...which will not be detailed here...I melted the last half-inch or so of the throttle tube on the '86 a couple of years ago. I cut off the offending section 'cause I'm cheap, and installed a new set of gel grips...which then squeezed down on that last half-inch of protruding handlebar tube, causing the throttle to bind.
Actually, "bind" is an understatement...I got a custom-built throttle lock. And not in a good way. It's still that way, but I've been using some cheapo semi-rigid grips from J.C. Whitney - $8 a pair, firm vinyl with foam overlay. They don't self-conform like gel grips. Actually, I kinda like 'em. Old-style Sunline grips would work, too.
Ya gotta cut the end of the grip off to use the bar-ends, but that's OK. They've got a stoopid-lookin' Harley-Wannabee eagle insert on 'em that just had to go anyway.
Rossi
tqmx1
Just to let you know all Yamaha sport bikes (no idea about crusers) use the same bar weight attach system (big threds screwing into bars or clipons) they might look different but attach the same way.
I got a set of FJ ends from big George and had them modded to use with my Vstrom hand gards on my Fazer1. So if I want to return to stock unscrew the weights and put the stockers back on.
the FZ1 handlebar weights are exactly the same as the FJ also.
tqmx1
Frank they are the same but different, if you get my drift.
n8man1068
Quote from: TRoy on March 09, 2009, 07:00:03 PM
They look identical to the left side weight. I haven't taken the weight off yet to verify, but the outer size and design is the same.
'86 FJ1200 gas tank
