Valve Cover Gasket Replacement - How Clean Does Valve Cover Need To Be?
Started by 86FJNJ, March 29, 2025, 09:42:37 AM
86FJNJ
I'm replacing the valve cover gasket on my 86, how clean does the gasket channel need to be? I scrapped away some of the larger gunk leftover from the last replacement and washed it with soapy water but there is still some residual gasket sealer leftover, although it's very minimal. I didn't want to scrap too hard and gouge or disturb the aluminum surface.
Am I good to install new gasket or does it need to be spotless?
1986 FJ1200 converted to Fuel Pump
You should never need sealant on the FJ's valve cover gasket. The valve cover gasket seals upon compression, as such you want to remove all the old left over sealant residue.
Acetone and the pointy end of a bamboo sis kabob skewer works for me.
Sparky84
Are you going to replace valve cover bolt grommets also, or have they recently been done ?
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
86FJNJ
I'm doing the bolt grommets as well, idk how old the existing valve cover gasket was but oil was leaking through down the heads so I'm hoping replacing the gasket and grommets fixes that.
Chainlube
Quote from: Pat Conlon on March 29, 2025, 12:43:44 PMYou should never need sealant on the FJ's valve cover gasket. The valve cover gasket seals upon compression, as such you want to remove all the old left over sealant residue.
Yea... At dealers we sometimes used gasket sealer just to hold the valve cover gasket to the cover while reinstalling the cover.  Gasgacinch was my go to.  Sorry about that.  :pardon:
1984 FJ 1100
2024 XSR 900
2015 V7 Racer
1978 KZ 200
That mostly looks like discolorization to me.  I'd install it as is - and like Pat said - no sealant required!
Be careful not to overtorque the valve cover bolts.  The long shoulder on them bottoms at the top of the cam caps.  If you try to force them tighter they simply break off in the cap (if you are lucky!  If you aren't lucky you strip the cam cap ...)
