1992 Parts avialable to a good home...
Started by axiom-r, January 04, 2025, 01:41:56 PM
axiom-r
Hello all –
I have parts left over from my mods that I will never use again....  I am very appreciative of the support and knowledge here on the FJOwners.com so I am offering these parts.  I would like to see these go to members that need them for immediate use.
If you see something on the list that will help you, let me know.
Parts are free – shipping (and packaging if needed) are on you. Please don't ask me to cost out the shipping if you are not certain that you want the part – or if the cost of shipping might be a "deal breaker" for you.  We can send it slow on the ground as cheap as possible – or get it there overnight. Your call.
Parts are from a 1992 FJ1200 ABS....  everything is in good condition.
AVAILABLE AND AS PICTURED:
SWING ARM
SWING ARM LINKAGE
CHAIN GUARD
RUBBER CHAIN GUIDE
REAR AXLE, ADJUSTERS, SPACER
REAR BRAKE STAY
REAR BRAKE CALIPER
REAR BRAKE LINE
SET OF SPROCKETS 17/45 – decent shape
OIL FILTER HOUSING, SPRING & WASHER + NEW FILTER
SPEEDO CABLE
SPEEDO DRIVE FRONT HUB
STOCK HANDLE BARS
STOCK TRIPLE SET CLAMP W/ STEM
STOCK TRPLE SET CLAMPS W/O STEM
FRONT BRAKE MASTER CYLINDER
CLUTCH MASTER CYLINDER - needs some love
CLUTCH PUSH ROD
SHIFT SHAFT WITH CLAW
axiom-r
Sprockets and Rubber Chain Guard - TAKEN
Rear Brake Stay, Caliper, Line, Master Cylinders, Pushrod - TAKEN
EFFJAY1100
If you find any left over Allen head bolts, the ones that connect the damper rod let me know. Thank you. :)
I'ld like to get the speedo drive and speedo cable if still available?
Thanks,
Chris
axiom-r
Quote from: fj1289 on February 08, 2025, 08:16:49 PMI'ld like to get the speedo drive and speedo cable if still available?
Thanks,
Chris
Chris - I am just home from travel.  I think they are still here - Ill check.  Send me a PM
