The Good, The Bad, and The Ugly
Started by JohnnyTheCraneGuy, December 29, 2024, 05:34:49 PM
"or just ride slowly and don't use the higher rpm power of the bike"
I think we must need a sarcasm icon/face thingy to go with that statement!   :lol:
I've used full-synthetic oil in my FJ ever since I've owned it...........never experienced any hint of clutch slippage, ever.
Probably tens of thousands of full-throttle pulls out of corners, and onto on-ramps.
It's not something I've ever had the need to be concerned with......YMMV
Have used many different brands of it over the years.......Lucas is good.
And we are off....
Gotta love these oil discussions.
I have the Barnett coil spring conversions in my FJ's so I have no problem with full synthetic oil.
What I've found is on long hot rides full synthetic oil does not burn off like the mineral oils.
That Lucas 10w-30 synthetic looks to be quality "motorcycle specific" oil.
 :wacko2: I'll add to the oil discussion. I also have only been running full synthetic. In all my bikes. Because I'm cheap, Rotella  T6. My 1350r 117ftlbs of torque 176hp. Doesn't slip. But I too have barnett coilspring clutch plate. And I generally just putt around on the 1350r. Will be using full synthetic on the turbo bike if I ever get back to that project.
 :sarcastic:  don't know how to delete. A post. Sorry about the double.
[edit] All fixed...Pat
JohnnyTheCraneGuy
Thanks for the tip Dean!
I put about 150 miles on her this weekend and didnt have any issues with slipping the clutch, in fact it was the tire!  :lol: Caught me by surprise when I was turning onto the onramp I came on her too right out of the turn, and she slid out to the right as I started going left!
I was honestly really surprised at how easily she handled it too, almost like these bikes want too  :mocking:
2003 XVS650 (Sold)
1990 FJ1200 Fiona
1986 FJ1200 (Parts Bike)
JohnnyTheCraneGuy
Well guys this weekend has been a blast! I put about 250 miles on the bike and she honestly handled all of it very well, except for one issue for me. I'm pretty sure I was experiencing the issue related to the 1st gen shift forks. It happened to me twice now where I would go to downshift into 2nd without using the clutch and it would act like it would go into neutral? No neutral light but it behaved like it was, I had to bang it down into gear again both times with a little grinding.
Now for the fun part  :flag_of_truce: on my way back, I was in 3rd around the 9k mark powering into 4th, and I noticed my headlight get brighter and then dim out, shortly after the oil level came on and I never heard the bolts snap or anything but I get home, drove maybe 10~ ish miles from when it happened to my driveway. Get off the bike and start inspecting and I see oil pissing out on the left side. I knew to check the generator because of the headlight and sure enough.
Well I was not expecting to end my ride like this but I am thankful it happened at the end and when I was near home instead of down in the Springs where I rode too. The part that's really bumming me out is the fact it broke  bits of the block off too with the bolts so I've got to figure how I'm going to get around that. Then of course there's getting the broken bolts out, not too terribly worried as I had taken them when I redid the wiring insulation on everything so at least I know they're not seized. Splines on the generator look good, didn't notice any play on the shaft so it could just be the broken bolts.
Still want to cry haha
2003 XVS650 (Sold)
1990 FJ1200 Fiona
JohnnyTheCraneGuy
Spoke with Robert this morning and went over a couple of options as far as drop in replacements go, all in all I would really like to save up for a 1250 rebuild with a core that they have. or maybe step into the 1300 range with the adults here  :biggrin:
That's going to take a lot of cold nights with sore knees but it'll be worth it in the end. I need the 3 bolt generator mount, I want the updated starter, and I sure as hell want a fresh gearbox. If I'm going that far might as well go the rest of the way right?
In the meantime, I now know that this of course ain't the first time this has happened so my tears have now dried haha
I'm going to soak the bolts in PB overnight and go to work with some left hand drill bits. I believe I'll pull through  :good2:
2003 XVS650 (Sold)
1990 FJ1200 Fiona
