Synthetic or Conventional Oil?
Started by 86FJNJ, October 22, 2024, 11:39:33 AM
86FJNJ
I've always ran full synthetic in my other bikes, since getting an FJ (which is not running...working on that), I came across a few people saying to use conventional to avoid problems with starter or clutch. What are you running?
Also, what viscocity are you running? 10w-40?
Warning!!! Oil thread....
Many will tell you to pick one (Dino/Syn) and adjust viscosity to taste. I found the starter clutch has a harder time in the cold with thicker oil. Not the oil's fault, the starter clutch is known to wear out. Keep it clean and topped off.
86FJNJ
Thanks, I did look around and didn't see any other posts so figured I'd give it a shot. I'll start with 10w-40 syn and adjust if needed.
Make sure it's motorcycle oil that's safe for wet clutches.
Automotive oil will cause your clutch to slip...guaranteed.
86FJNJ
thank you and yes def motorcycle oil
chiz
86FJNJ
My opinion and advice on oil for motorcycles is this.
The engine does not care what Brand or type (conventional/synthetic) is used. The engine cares that there is an adequate amount, the correct viscosity for your temprate zone, and that the oil has the JASO MA or JASO MA2 rating. Beyond that, everything is Smoke and Mirrors on which is best.
Nikos
Nick the Greek
moparman70
I changed to synthetic oil in the FJ mainly due to it handles the heat better when traveling longer distances.  Yamalube syn was a good value.  10w40
Quote from: moparman70 on December 04, 2025, 11:39:57 AMI changed to synthetic oil in the FJ mainly due to it handles the heat better when traveling longer distances.  Yamalube syn was a good value.  10w40
Yes, I have also found that to be true.
 An ester stock synthetic does not burn off on long rides, especially when crossing the toasty Arizona desert in summer.
