85 FJ1100 Turn Signal Issue
Started by gmly, October 02, 2024, 11:20:53 AM
gmly
Hi Fairly New to Forum
Owned an 85 FJ brand new when i was young man
Sold it
39 years later bought another one
Issue is no turn signals
I once saw the orange right indicator light come on dash when i activated signal but only for a split second
Now i occassionaly hear a short buzz from relay on left side of fairing when using the switch on handlebars but no signals working at all..
I pulled the two wires from the connector (chocolate and chocolate with white stripe) hooked up a car flasher 2 prong and nothing.
Getting approx 11 volts on chocolate wire..
Can any one help me out ?
Thank you
Check fuse
Check grounds
Clean the contacts in the handlebar switch, lots of crap gets accumulated in there.
Jump the wires to bypass the handlebar switch to see if the problem lies there.
If no go, assume it's the flasher box. The self canceling turn signals have a connection to the odometer,(distance) see it that still working.
Welcome back to the FJ world.
If you need a wiring diagram, there is one in the back of the Owners Manual, see my signature line, you can down load one for free.
Pat
gmly
Thank you for the reply
Will try all steps you mention
Not sure about the self cancelling turn signals
I'm in Canada don't ever recall my original FJ  having  signals shut off by themselves
MarioR
It does not matter how slowly I go as long as I do not stop.
