84 Fj 1100 progressive dampening rear shock Question.
Started by Lloyd Van Duzen, June 30, 2024, 04:45:16 PM
Lloyd Van Duzen
I'm wondering how this adjustable shock works.  It has remote adjuster small sprocket turning a larger sprocket on top of the rear shock.  Does the larger sprocket compress and decompress the shock spring?  And has a screw speedo cable like thing that turns as well.  This is for dampening and response I think.  Can someone direct me to figuring this out.  I took mine out to clean up and free the rusted little chain too.  Seems pretty hard to turn the big sprocket with the remote turn dial. Thanks for your help.
1984 Fj 1100
mike g
chain does the preload
cable does rebound damping
higher numbers mean harder
i'm running max on my 3cv
