New to the forum
Started by RidingAgain, December 20, 2023, 11:07:53 PM
RidingAgain
Finally have a FJ1200 a 1990 beautiful dark blue with some minor cracked plastic. Have admired them since the FJ1100 came out. Kids are grown so no more reasons not to start riding again.  Only draw back on this bike is the chain, almost went for a FJR1300 for the shaft drive, but the desire always went back to the FJ1200 so I guess I will learn to maintain the chain.  Started riding dirt bikes as a kid, then street bikes, have ridden coast to coast and am looking forward to doing that and much more on the FJ1200.  but before riding this beast on the road I need to bring my street skills back up with a safety course.  Really looking forward to riding the roads again.
Matthew
1990 FJ1200 new to me 2023
Welcome to the FJ world. The plastics are fixable, the bike easy to work on. Big plus on the safety course, keep the rubber side down.
Welcome to the Forum   :hi:
Chain technology has come along ways since the FJ was 1st introduced. A modern, high end chain will easily do 20,000 miles with proper maintenance.
All of my bikes use a 530 chain. My go to chain is the EK brand 530 Z3D. It has one of the highest tensile strength ratings and the mileage longevity is there.
The 1st photo is an add photo, 2nd photo is a EK530 Z3D on my Streetfighter 1200
Welcome! I hear you on the chain concerns. What I have learned thru the years is that FJ's are hard on chains, *so buy a top quality chain* After the initial break in, I have found very little stretch thru the life of the chain. I use the DID ZVM chain and I can get 40-50k miles. I replace both my sprockets and chain at the same time. I run my chains on the loose side of adjustment. A loose chain is a happy chain.
Cheers.  Pat
I'm with Pat 100% on this - my chains last 40,000 miles with only occasional cleaning and regular spray-on lubrication (GT85). Hardly ever need adjustment after initial break in........and I don't always ride slowly !!!!!
Chainlube
Quote from: aviationfred on December 22, 2023, 08:52:01 PMWelcome to the Forum   :hi:
Hi Fred.  Where did you find the chain guard?
1984 FJ 1100
2024 XSR 900
2015 V7 Racer
1978 KZ 200
Riding,
Welcome to the madhouse.   :biggrin:   These days, you can get O-ring and X-ring chains.  They ride long and hard. Replace the sprockets with the new chain, as noted above. The take-offs will be backups for you.  RPM owns this forum, and it's a great source for FJ-specific parts and accessories. We can also out-source many parts that will keep you rolling.  This link is for the California model, and there is a similar page for the non-CA bikes.  Several on-line FJ shops have these Parts Fiches:
FJ1200 parts
Keep us posted.  We like pix.
Quote from: Chainlube on March 25, 2024, 12:11:56 PM
Sorry for the delay in response. I got the chain guard from an FJ owner in The Netherlands. Sadly he passed away a few years ago.
JohnnyTheCraneGuy
I wasn't able to find an answer in the service or owner manuals I've downloaded but I was wondering do I replace the chain with one that has 120 or 150 links? also how many teeth on the rear sprocket are yall running?
2003 XVS650 (Sold)
1990 FJ1200 Fiona
1986 FJ1200 (Parts Bike)
T Legg
The 120 is plenty long enough.my chain length was 110 links for the stock 17 and 42 tooth set up of the fj1100. I just put new sprockets on that are 18 and 40 tooth sprockets and my chain length is still 110 links. Im not sure but i think with the 18 tooth primary sprocket and a rear sprocket with less teeth than 40 you would have to drop down to a 109 link chain.
T Legg
Quote from: T Legg on January 27, 2025, 01:05:39 AMThe 120 is plenty long enough.my chain length was 110 links for the stock 17 and 42 tooth set up of the fj1100. I just put new sprockets on that are 18 and 40 tooth sprockets and my chain length is still 110 links. Im not sure but i think with the 18 tooth primary sprocket and a rear sprocket with less teeth than 40 you would have to drop down to a 109 link chain.
No need to drop down Travis - i run 18 front and 38 rear sprockets, with the stock length 110 chain and the axle sits nicely in the adjustment slot range as new. If the bike was fitted with 18 and 40, or 18 and 41, I might consider going for an extra link or two.
Riding Again - stick with a stock 110 chain and go for 18 and 38 sprockets would be my advice for a 1990 (3CV) 1200, unless you're a stoplight drag-racer.
JohnnyTheCraneGuy
Thanks yall,
I've been browsing rpm looking at their sprockets and I'll definitely take what yall are running into consideration. I'm used to my shaft driven XVS LOL so this'll be my first time tuning the driveline on a bike. Personally I would like to tune more the low end. I plan on spending most of my time on the backroads instead of the highway so I feel like that's the direction I should lean towards. They do have a 38 rear and 18 front so I'll probably grab that.
Take care yall until next time.
2003 XVS650 (Sold)
1990 FJ1200 Fiona
T Legg
http://www.fjowners.com/index.php?topic=669.0
      This is a link to a chart that shows the relationship of rpm to mph for different sprocket and tire combinations.
T Legg
JohnnyTheCraneGuy
wow was I backwards  :biggrin: thanks for the save man
2003 XVS650 (Sold)
1990 FJ1200 Fiona
Motofun
No one mentioned that you should get a rivet link design, and a tool to install it (I use a DID tool).  Not many things can ruin your day like a chain failure and a ruined engine case.
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
