December 03, 2023, 05:18:41 PM *
News:            Enjoy your FJ
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Ultrasonic cleaner wide enough for a full rack of carbs.  (Read 473 times)
Super Hero Member
Offline Offline
« on: October 02, 2023, 11:51:31 AM »
Well I finally broke down and bought a ultrasonic cleaner.  I have only ridden my beater bike my 89 fj this year due to getting a job at a new company after 37years at quad. And now starting in the new heat treat department.  Anyway. I'll be cleaning carbs on atleast 6 of the 13 bikes that I own next year.
It's a 22L vevor $208 delivered. It's 20" wide so plenty of room for a rack of carbs.
Logged
Administrator
Super Hero Member
Offline Offline
Gender: Male
Team RPM
WWW
« Reply #1 on: October 02, 2023, 04:25:09 PM »
Dan,
Please do not clean the carbs assembled as the rack. There is no way to get the water and soap solution out of many crevasses when assembled. Take them completely apart.
BTDT and learned the hard lessons
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #2 on: October 03, 2023, 05:39:09 PM »
Randy, what is that $$ special cleaning solution you use?
Logged
gdfj12
Silver Contributor
Full Member
Offline Offline
1989 FJ1250 w/XJR bits & 1987 FJ1200 . .see sig.
« Reply #3 on: October 04, 2023, 08:35:27 AM »
I've been using the Simple Green Aluminum safe stuff,
https://www.amazon.com/Extreme-Aircraft-Precision-Cleaner-13406/dp/B001VXU7OE/ref=sr_1_3?crid=1EAMKIZUXEVJ0&keywords=simple+green+aluminum&qid=1696429937&sprefix=simple+green+aluminu%2Caps%2C948&sr=8-3
It works nice on all of the aluminum bits I have been cleaning and repainting or powder coating. It won't eat away the metal like some chemicals will, DON'T use the regular Simple Green on aluminum.
I concur with Randy, disassemble as much as possible to allow the cleaning solution to get onto all of the surfaces and to get it rinsed off as well, then reassemble. I use Parker O-Lube on the o-ring seals and the diaphragm sealing beads to promote good seals and potentially increase the life of the seals.
Logged
George D
'89 FJ1250 ~'90-black/blue
'87 FJ1250 ~streetfighter project
'89 FJ1200 ~white/silver, resto project
'88 Honda Hawk GT, resto project
RPM - Robert
Administrator
Hero Member
Offline Offline
« Reply #4 on: October 04, 2023, 09:34:57 AM »
Chem-crest 235 is what we use and has worked very well without discoloring of aluminum and other parts.
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #5 on: October 05, 2023, 08:53:11 AM »
Thanks George and Robert!
Logged
Super Hero Member
Offline Offline
« Reply #6 on: October 05, 2023, 11:52:06 AM »
Yes thanks much. I was planning on taking the carbs apart just didn't want to take the rack apart. Had heard that simple green pro hd purple concentrate was aluminum compatible and cheaper.
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #7 on: October 05, 2023, 02:55:40 PM »
I thought so too Dan….until I found that I had to separate the carbs anyway to get those fuel inlet T’s and bowl vent T’s out to replace the o rings.  Lesson learned:  I have soaked an assembled rack of carb bodies (carbs disassembled) put everything back together with fresh o rings (almost all new o rings) then have those darn fuel inlet T’s start dripping fuel…….crap….
Logged
RPM - Robert
Administrator
Hero Member
Offline Offline
« Reply #8 on: October 05, 2023, 09:05:06 PM »
You have to so that you can get all of the water/cleaner out of the carbs. Those places like the tees hold the water/leaning solution and will either contaminate the fuel when the bike starts or continue to etch the aluminum when the water/cleaner gets between the dual o-rings. Lets not get started on the tiny orifices of the choke circuits...
Logged
Pages: [1]   Go Up
  Print
Jump to:
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
