Fjr1300 clutch master on a 1100?
Started by Fj1100 Rebuild project, August 13, 2023, 01:20:30 PM
When I bought my bike it was missing the slave cylinder, clutch line, and clutch master cylinder. I have since found a slave cylinder and line but have not been able to source a good condition master cylinder. I have however been able to find one off a fjr1300... will this be a direct replacement for my 1100 and if not can I modify it to work? Thanks
Yes, many of us use the FJR clutch master. It has a neat adjustable lever. On the clutch safety switch, you will have to modify the plug on your FJ1100 wiring harness. I crimped on 2 female spade connectors that fit the blades on the FJR master.
Pat
