New brakes time
Started by Waiex191, July 30, 2023, 09:52:26 PM
Waiex191
Take a listen to the noise my right caliper makes when I squeeze the brakes:
https://youtu.be/9d0rIhnQXyU?si=iECI-r3tNhZMEg1g
It was doing that before too. I took my calipers all the way apart again and didn't see anything. Made sure they were clean, and reassembled with plenty of fluid during assembly. I also replaced the copper washers which I skipped last time.
Any ideas on the noise and if it is a clue or not?
Brakes have improved a little bit but still not good.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex,
Dis-assemble, clean and lube all of the pivot points on the front brake lever, first.
Keep us posted.
Waiex191
Quote from: red on September 04, 2023, 07:16:03 AM
Waiex,
Keep us posted.
I'll do that. The brake lever feels great though, I have been pumping it a lot. When I put a finger on the outside of the right caliper I can feel it as well as hear it.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex191
I did the bungee the lever to the handle trick overnight.  Big improvement, and I've got the bungee back on it.  Haven't had a chance to do the pivot yet.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex,
The caliper body has to slide left and right, to center itself on the disk.  Make sure that the caliper is free to move as it should on the mounts.  You may need to remove the brake pads to check this.  Do not move the brake lever, and you should be able to re-install the brake pads without much trouble.
If the caliper is not free to move, one pad may remain touching the disk, causing the disk to get HOT (not just warm) and that can cause a brake failure or even a lockup.
Waiex191
Quote from: red on September 04, 2023, 03:32:14 PM
Waiex,
These are 4 pot calipers that bolt hard to the forks - they don't float like my old Suzuki calipers that only have a piston on one side.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Old Rider
I think that is just the pads slapping into the rotor take a close look and se if they move
Old Rider
Or the pistons slapping into the pad. If it is the piston coppergrease or special brakepad tape on the backside of the pad is a solution.
On my last pad change to High sintered i got a similar sound, but that was when driving in slow speed and it was the pads moving forward inside the caliper and make a clicking sound when brake aplyed .Some more coppergrease stops that .
Waiex191
I looked last night and didn't see them moving. Pads are on the rotor and they just squeeze.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex191
I added a bleeder banjo bolt at the MC and also did some reverse bleeding as some have described.  No real change, I am going to try rebuilding the MC next.  I also have another set of calipers on the way from ebay.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
RPM - Robert
There is a secondary super tiny hole in the mc that gets clogged easily. When it's apart you can shine a light up the bore and make sure it is unclogged. I don't know how big the dang thing is but seems like it's 0.0001" you won't be able to get the brakes to bleed if that is clogged.
Waiex191
Quote from: RPM - Robert on September 08, 2023, 09:56:49 PM
Thanks!  I'll look for it.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
melloncollie
Any luck with your brakes?  Earlier you were concerned there was a leak: did you see fluid anywhere it shouldn't be?  Is the fluid dropping/lever getting soft overnight?  Any blemishes on the pistons that you saw during rebuild that might cause a leak past a seal?
89 FJ1200
Mikuni RS36, Hindle 4-1, Blue Dots
Waiex191
Quote from: melloncollie on September 10, 2023, 10:54:12 PM
I saw no leaks. There was some corrosion on the part of the piston that pushes the pad, but all outside the seals. Plus it was like that before. This week I'm going to pop off the MC and replace the seals, and look for the tiny hole Robert mentioned.
It's not getting soft overnight, just never getting hard.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex191
The small hole in the MC seemed clear. There are only two holes unless I missed one. I put new seals in the MC and it seemed a lot better, but now I have a sizeable leak getting past the piston. Very frustrating.
I also found my used MC had a busted brake lever.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
