petcock turning tool
Started by gggGary, April 19, 2023, 07:12:21 AM
gggGary
A first version but it works!  just some aluminum I had laying around.
I'm thinking if I do a mark2 it will have more of a U shaped handle. turning back up alongside the tank.
FJ1200AE
Just one more Honey.
balky1
I don't get it, you need this for what?
FJ 1100, 1985, sold
FJR 1300, 2009
JPaganel
Quote from: balky1 on May 08, 2023, 09:03:09 AM
I'm guessing it's for the 89 and newer petcock that the fuel pump models have. It has a square peg this would fit.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Waiex191
I use an open end wrench on my '89 petcock. Works great!
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Urx
Yep 10mm spanner if i recall
Stainless lines
Blue spot calipers but std m/cyl (so far)
Ebc prolite front discs
Ohlins remote adj rear shock
Remus 4:1
Still running original chain and sprockets from new (scotoilers really work)
Krauser k2s
Quote from: Urx on May 08, 2023, 01:31:48 PM
10mm? I thought it was 8mm.
RPM - Robert
Urx
How can you tell its been ages since the tank was off my FJ LOL....YES 8mm open ender
Tank and fairing will be off over the next few weeks as i strip off an ancient and annoying alarm as well as fitting the new front end and powder coated  fairing bracket. Depending how that mission goes i,may just plough into the swing arm swap as well...we shall see.
Stainless lines
Remus 4:1
Krauser k2s
RPM - Robert
Only the left side cover has to come off to access the petcock with the open end of a standard 8mm.
