FJowners.com
March 26, 2023, 03:25:58 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: This forum is run by RPM and donations from members.
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Oil pump cover split  (Read 81 times)
kb277
Newbie
Offline Offline
« on: January 01, 2023, 05:23:29 PM »
I’ve had an old fj1200 for a few years now and use it to do winter hack running and some charity events. Anyway I lent it to a mate who had just passed his test to get some experience on as he couldn’t afford to buy anything at the time. He ran it for about a year and put around 6k on the clock. It’s coke back in need of a lot of work such as fork seals, rear shock, starter motor etc etc. I have all the parts anyway but I noticed a big crack on the oil pump cover on the left hand side of the engine. Can anyone tell me if this would be “wet” in behind or is it more of a dirt cover? Effectively I’m trying to work out if I need to source a new one of if I can simply silicone it up.
As I mentioned it’s a winter hack, it owes me nothing and is worth nothing so looking pretty is not a must here.
TIA
Keith
Logged
RPM - Robert
Administrator
Hero Member
Offline Offline
« Reply #1 on: January 01, 2023, 06:12:53 PM »
The cover with Yamaha engraved is the ignition pickup and rotor cover. I would get a new one to protect the ignition system from the elements for 100% peace of mind.
Logged
kb277
Newbie
Offline Offline
« Reply #2 on: January 02, 2023, 04:23:43 AM »
Perfect thank you. I had it in my head it was for oil pump? I will remove and seal/weld it up.
Many thanks.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
