Instrument cluster maintenance
Started by aigram, September 21, 2022, 12:52:14 PM
Quote from: red on October 06, 2022, 11:23:42 AM
Quote from: ribbert on October 06, 2022, 07:40:10 AMMulti grips are the perfect tool for this. I don't know if they are called that in the US but this is what I mean......
https://live.staticflickr.com/65535/52408555629_f492e4b67f_b.jpg
Noel,
In the USA, they are commonly called
slip-joint pliers.  They may have only two or three settings.
or
Channel-Lock pliers (same function, maybe a stronger mechanism).  Channel-Lock is a brand name.
Locally here they're called "slip grips".
Aigram,
I have seen speedometers and tachometers that have the "resting pin" of the instrument covered by a short piece of wire insulation (stripped from the right size of wire).
The insulation was just long enough to prevent the insulation from coming off the pin - the instrument glass held it in place.
Just guessing, but that may have been done to fix a sticky situation at the pin.
Motofun
Noel,
or
All true but I still call them channel locks....just like I use Kleenex, Xerox... :Facepalm:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
