Valve Clearance adjustment
Started by krusty, July 24, 2022, 09:54:38 PM
krusty
Ok. About two years ago I pulled the top end from one of my 1100s to see why #2 had no compression and I found a broken valve. I have now replaced the damaged valve and one other that was fairly poor. At the time I purchased a valve compression tool, as pictured. I am now thinking this tool will not work as it has only one "prong"(?) and not two as I have seen with others. The mounting holes do not appear to line up either. Is the tool with two "prongs" the only one that will do the job?
:yahoo:
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
RPM - Robert
Yes the two prong is the only one that will work. You got a tool from someone who didn't know what they were selling. We see this commonly here. Motion pro sells that tool for cheap for the 1100/1200/1250 but it won't work.
That tool is for the 2-valve Yamahas like my old XJ650 Seca
