17" Wheel Conversion Woes
Started by ajacstern, May 27, 2022, 01:58:21 PM
ajacstern
Also apologies for so many little questions but the wiki lists the 89 forks as receiving 395cc / 169mm from top of oil where as the 87 are supposed to get 424cc / 141mm from the top. I did 125mm from the top fully compressed without the spring in on my 87 forks and liked the damping, can I just do the same or do the 89's actually need a different oil level?
I'd start with the 125 mm - what you are playing with there is how much air is in the fork that will also compress with fork travel.  If you liked just a little bit before - should be similar.  More air "should" give you a little more bottoming resistance.
ajacstern
I have put almost everything back together. I believe I actually did 145mm air gap for the '87 forks or something, the '89s are probably 15-20% stiffer on compression at 130mm but I want to run it and see how it feels, may help eliminate brake dive.
I installed the blue dot Yamaha calipers and bled them, several times. Almost no lever pressure. It does grab the wheel and stop it from moving, but almost no resistance in the lever. I noticed there is a loud almost squeaking noise coming from the left caliper. I can't see any leaking brake fluid (though it is still a bit wet from being bled), but it almost sounds as in if a piston seal is collapsing underpressure. If I hold the lever ~70% of the way in and move just a little bit, a few mm, it will repeatedly make the noise every time I pass a certain lever point. When pressing the pistons back in to fit onto the wheel I heard the noise as well. Is that something that is possible? Wondering if all the fluid pressure is going into deforming a seal and thus no braking pressure.
Thank you.
Squeaking could also be air bubbles compressing. I had a similar issue when I first installed my blue spots (and also had a similar issue with my clutch at one point).
Getting a small amount of brake pressure with a soft lever definitely sounds like trapped air to me - I now "reverse bleed" all of my hydraulics - the idea is that you push brake fluid in through each caliper bleed nipple (one at a time), using either a big syringe or a small hand pump) and you push fluid into the caliper and back up to the master cylinder. As any air in the system wants to rise, it will pop out of the open top of the master cylinder. Just be careful to push/pump slowly and maybe put a cloth over the top of your open master cylinder, in case any fluid spurts out. Just be sure also to not overflow/overfill your master cylinder. I use a small "Laser" brand mini hand pump, filled with fluid and pump it through the slightly cracked open bleed nipples.
Since using this bleeding method, all of my hydraulic problems have disappeared.
Another trick to help bleed a "new" system is to slightly loosen the banjo bolt at the master cylinder to bleed the air in the line easier.  Pump up what little pressure you can and hold the lever, wrap a rag several times around the joint, and just loosen the banjo just enough to relive the pressure, snug down the banjo and release the ever.
Then it will usually bleed much easier no matter what technique you use.
ajacstern
The reverse bleed is my favorite method as well, that hand pump looks like a much better option than the syringe I currently use. I also typically find myself using that master cylinder trick when changing master cylinders. However, the issue turned out to not be with bleeding technique. There was some hairline fracture on the bleed nipple which prevented it from being able to build pressure, and I couldn't tell that they were leaking because they were already a little wet from the bleeder hose. Switched the nipple out and it bled properly the first time. The popping / crinkling sound was from the brake hardware being a bit bent / warped out of shape, it turns out.
Got everything together and went out. Much happier with the damping at 125mm, suspension feels way better than it used to (part of that may be from fresh bushings and such as well). The front wheel feels fine, the low speed handling is fixed surprisingly and the high speed handling is slightly improved but I still think I will raise the forks a little bit. Bike feels very communicative and is still comfortable to ride, definitely like these tires, though I can't comment on the limit of grip on the front yet.
Unfortunately, there is always something, and the reason I can't speak to the limit of grip on the front is due to the front brake rotors being fubar. Massive vibrations at high speed, and at low speed I can feel the brake grab and release with every wheel rotation. Right rotor was 10 thousands of an inch out of spec and the left was 2 thousands of an inch. I tried to correct it with a prybar as the braking surface itself is flat, it is the brake carrier that is bent, but as soon as it got hot it returned to shaking. Guess I need to replace them unfortunately.
Are these https://www.ebay.com/itm/265713520064?fits=Year%3A1989%7CModel%3AFJ1200&hash=item3dddc28dc0:g:PgcAAOSwWWZik5As rotors known to be any good? The only ones I see are these Chinese ones, some Arashi ones, and some very expensive EBC rotors. I like the stock rotor design, not such a fan of the Arashi wave unless there is some advantage to it, but not sure if Chinese brake rotors are acceptably safe.
Thank you!
MarioR
Quote from: ajacstern on May 27, 2022, 01:58:21 PMHello all,
Hope everyone is doing well. Over the winter I decided to convert my '87 FJ1200 to 17" front and rears. So far I have only converted the rear as I wanted to get a feel for the difference each individual change made. I used a 93-97 gsxr1100w rear wheel (I believe) and a 180/55/17 Dunlop Roadsmart 4. 38f/42r psi. For the brake I wanted to keep the original mounting point so I used a GSX750F Katana rear caliper and torque arm, had to hammer the torque arm a little for clearance but it bolted right up after that. Unfortunately, removal of the rear wheel now requires removal of the caliper as well, not sure if that is the same with the underslung, if not then I may switch to the underslung after all.
I went out for a test ride and at first it felt great. Tire heated up very fast, quite sticky, feedback and compliance felt good. On low speed turns the bike felt like it wanted to fall into them and you had to turn the bars the other way to keep the bike up, but it wasn't crazy bad given I don't do Motogymkhana. Once you got to 20-25mph the handling feels absolutely perfect. However, at high speeds (55mph+) the handling is incredibly stiff, takes your whole body weight to switch lanes quickly. This problem was present with the old wheels too and is the main reason I switched, though it feels a little bit worse now. I am hopeful that switching to a late model front wheel and raising the forks will fix this.
The biggest two new problems come in the braking department. I tried to trailbrake a little bit and the bike violently shot upright, much more than it has ever done before. It used to be fairly accepting of trail braking but now it is barely possible to turn and brake at the same time, this is using the front brake. I don't know if this is because of the wider rear, 0.3" lower rear ride height, or switch to radial tires. Has anyone had this and found a fix? It is bad enough that I would go back to the 16"s which I really don't want to do. The other issue is that this rear brake is barely a suggestion. It is functional, but even if I stand on it with my heel it can't lock up the rear and barely slows the bike down. If that is somewhat normal I will switch to sintered pads but don't want to throw money when the caliper is simply not up to the task...
Thank you!
So FZR 1000 87/88 front wheel fits 86/87 forks set up?
I have 86 with progressive springs, just rebuild and anti-dice plate and wondering if I can put FZR rim straight on it.
Thanks  :morning1:
It does not matter how slowly I go as long as I do not stop.
Quote from: MarioR on February 24, 2026, 04:09:50 PMSo FZR 1000 87/88 front wheel fits 86/87 forks set up?
Thanks  :morning1:
I put this same wheel on my '86, then moved to my 89'. Add the RPM fork valves and the front end is greatly improved.
MarioR
Quote from: FJmonkey on February 25, 2026, 10:32:28 AM
Thanks  :morning1:
Do you remember spacer specs???
I don't recall any spacers, direct bolt on for 88/89 forks. Even uses the stock speedo hub.
MarioR
Quote from: FJmonkey on February 25, 2026, 12:46:44 PMI don't recall any spacers, direct bolt on for 88/89 forks. Even uses the stock speedo hub.
Thanks. I'm trying to use it with '86/'87 forks.
It will need to be fitted to make it work.
Thanks
Quote from: MarioR on February 25, 2026, 12:53:04 PMThanks. I'm trying to use it with '86/'87 forks.
Thanks
I put 88/89 forks on my '86. This was due to wanting the Blue Dot calipers. They will not bolt on to the '86 forks directly.  The other consideration is the rotor size on the FZR wheel. You will need to find a rotor of the correct diameter and if needed, an offset to center the rotor in the caliper. The 88/89 forks makes all that crap a simple bolt-on.
MarioR
Quote from: FJmonkey on February 25, 2026, 03:10:36 PM
Thanks
I am thinking on this one to keep forks....already rebuild with progressive spring, cartridges and plates. Did bracket for Tokico calipers as well....
[/quote]
Sounds like you will need to find the right diameter (check the thickness as well) rotors and make sure they are set the same width apart as the '86 when mounted, so they center in the calipers properly.
MarioR
Quote from: FJmonkey on February 25, 2026, 03:53:58 PMI am thinking on this one to keep forks....already rebuild with progressive spring, cartridges and plates. Did bracket for Tokico calipers as well....
[/quote]
Yes, this is correct.
Anyone install entire 87/88 FZR front end? Any benefits other than wheel and rotors? Does it fit?
