Throw out bearing
Started by Chrisdzu, October 02, 2021, 08:22:02 AM
Chrisdzu
I'm working on a 1985 fj1100. If the clutch pushrod shot out of the seal because it was started without the slave cylinder on, what's the chances the throw out bearing ended up in the bottom end?
On the British bikes it can easily fall out, I'm not too familiar with FJ's
Many thanks
ChristopherD
You should be fine - NOT the first time this has happened on the list!   Did you spear the cat with the rod?!
Yep, we consider it a right of passage....
