fuel control unit
Started by Stevecampy, August 09, 2021, 04:43:22 AM
Stevecampy
Hi to save me working out what connection does what.pleade help with a wiring diagram for unit/relay and what it does Thanks .its on a 87 1tx .so far switch and soliniod work if wired from battery. voltage at switch is lower that at battery when using bike wiring odd ,I think .got a earth and a feed to switch and wires to soliniod all ok
Hi Steve, the wiring diagrams are located on the back pages of your Owner's Manual.
Lots of good stuff in there.
Quote from: Pat Conlon on August 09, 2021, 08:54:02 AMHi Steve, the wiring diagrams are located on the back pages of your Owner's Manual.
Steve,
+1 on having the right Owners' Manual in hand.  If you need an enlargement of the wiring diagram, the right computer guy (yourself or others) or a copy/graphics shop can do the deed.  I got mine laminated, to keep it clean.  It helps to use index cards (or any rectangular paper) to follow a line across the page.
