1996 FJ1200 - RPM fork valve, spring, brake lines
Started by Storleer, April 23, 2021, 02:39:28 PM
Storleer
Hi all.
Recently bought a 1996 model FJ1200 NON ABS (EU-model) with 19k miles on the clock.
I would like to upgrade suspension, front and rear. So I believe the bike is a 96 model, but dont know for sure, might as well just be a 95 model sold and registered in 96. Anyway, for the front fork spring, I noticed that the upgraded ones that RPM sells are for 84-93 only? Did Yamaha change anything for the last models, so that these would not fit my bike?
Fork springs: http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3AFS.85
And RPM fork valve: https://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3ARPMForkValve
And for the brake lines: http://www.rpmracingca.com/proddetail.asp?prod=S-YA0147&cat=39
Regarding brake lines, it says (Original 3 Line 88-94), as my bike is not a 94, but has 3 lines up front, would these fit?
Thanks in advance :)
The FJ was last sold in the USA as 93, they continued to sell the 93 in other countries as 94+ so all the parts will fit.
Storleer
Great, thanks for your reply. Wow, this is going to cost, but will be worth it as I intend to use the bike alot.
As for banjo bolts, I want to renew those in the front as well. How many and which do I need? Three singles and one double?
I am not that experienced when it comes to these things.
RPM - Robert
3 single banjo
1 double
The kit has all of the crush washers you will need
Doesn't the Spiegler line kit come with new banjo bolts?
RPM - Robert
Quote from: FJ_Hooligan on April 27, 2021, 05:57:00 PM
They do not, unless, it is the alternate two line kits. They come with the "required" double banjo to swap from the 3 line to the 2 line. But the normal kits do not.
ELIMINATOR
Fork valves and springs made a noticeable difference to my bike.
BMW 1150GS
Moto Guzzi California 3
