Help needed with info. on FJ oem spring data for our Files section
Started by Pat Conlon, May 16, 2010, 03:13:48 PM
jamesearthdrum
Hello Pat,
         Just read this thread. The OEM rear spring diameter on my 89' was 88mm. Probably the same from '88 - 91'. Penske Sport shock is the same dia.
james
peace:)james
~~~friederich nietzsche ~~~
Thanks James, I'll add it to the file!
Quote from: jamesearthdrum on May 24, 2010, 11:12:18 AM
Hello Pat,
james
Pat,
Rear OEM Spring Rate for '91-93  FJ1200s is ~700lbs/in.  Determined by test on 2 used OEM springs.
Sorry I took so long to reply, I misread your initial request.
Thanks Arnie!
I have metric values shown in the table, so help me here, a spring @ 700 lbs/inch would be what, about .806 kg/mm correct?
http://www.onlineconversion.com/torque.htm
Do you recall the diameter of the shock spring? Is it 88mm like the earlier FJ's?
LA Mike
Pat,
Took my the spring off my 89 Fj shock to see if would work on a fox shock I'm rebuilding, race tech measured it just shy of 1075#'s. I would think that the '88,89 and 90 FJ would be the same, but the '88 was never sold in the USA.
LA Mike
Thanks Mike, so that would 1075 lbs/inch correct? Which should be about 1.23 kg/mm, I think...
Quote from: LA Mike on May 25, 2010, 11:14:18 AM
LA Mike
Quote from: the fan on May 25, 2010, 11:59:23 AM
19.2 kg/mm, but who is counting... :flag_of_truce:
Hmmm,  I'm doing something wrong, figures.... So,  Mike's 1075 lbs/in would be 19.2 kg/mm ?
Then using Arnie's 700 lbs/in would be what? about 12.5 kg/mm?
LA Mike
Quote from: Pat Conlon on May 25, 2010, 12:18:01 PM
When I was out at race tech they told me it was 19.2kg/mm, I just rounded it to 1075lbs/in when I converted it.
To convert kg/mm to lb/in you divide by 0.0179     19.2/0.0179 = 1072.6256lbs/in~1075lbs/in
LA Mike
Hello Pat,
james
James, was this diameter ID or OD? Thx
jamesearthdrum
Quote from: Pat Conlon on May 27, 2010, 11:56:05 AM
Hello Pat,
james
That is OD. I plan to remove the swing arm from the '85 to check the bearing and lube it. I'll measure the shock while it's apart.
peace:)james
FYI: I just measured my 89 OEM shock and the Outer diameter of the spring is 88 - 89 mm as well.  Oh - and the total shock weight is 7.5 lbs.  This will be the same for the 88-90 FJs.
