Starter Clutch Failure
Started by aviationfred, December 28, 2020, 12:34:10 AM
Robert,
Thank you for reminding about the cam chain tensioner.
Today's work. Carb cleaner and some brush work to care of any loose paint and old road grime.
I have decided that the is too much black.....
Yep, some break up of the black looks good!  :good:
Also do your the edges on lower cooling fins.
Timing is set and valve clearances are good.
Here is a handy tool. Nobody in the Mouse and Toad Garage could remember ever using it. Definitely came in handy for doing the torque on the cam sprocket bolts.
Flynt
Quote from: aviationfred on January 17, 2021, 05:15:23 PM
How do you compensate for the wrench length when setting the torque wrench?  I've seen fixed length versions, but never a slide/variable length version.  Do they have a conversion table or something?
Quote from: Flynt on January 17, 2021, 05:33:40 PM
As long as the added wrench is 90° too the torque wrench, no conversion is necessary.
https://www.motionpro.com/a/adjustable-torque-wrench-adapter-08-0380/
FJ1200W
Quote from: aviationfred on January 17, 2021, 05:41:42 PM
I've got to add one of those to the list!
Motion Pro is always coming out with cool stuff.
Columbia, Missouri
USA
Flynt
Boy that's counter intuitive...  I'd think it would be more like your torque arm becomes the length of the Hypotenuse of the triangle you made with the extension...  For example, if your wrench is 4ft, your extension is 3ft, your new effective torque arm would be 5ft (3,4,5 right triangle).  It would be a good approximation to say the extension is effectively zero as long as it's much shorter than the torque wrench, but imagine you have a 10 foot extension and a 1 foot torque wrench...  I don't believe you could ignore the extension in that case.
Anyway...  cool tool agreed and I'm going to get one.
Motofun
[/quote]
[/quote]
Draw a force diagram showing the applied torques.
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
Waiex191
For the hypotenuse to be the lever arm, the applied force would need to be perpendicular to the hypotenuse.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
A little help please...... I don't know if I am having a case of the Dumbass or what. For the life of me, I can't remember what gets mounted too these holes.
This is on a 91 and later engine. The holes are just aft of the oil pan. They have a machined surface and the threads are clean.
jono
on my 91 3xw the standard 4 into 2 collector mounting bracket bolts to those 2 threaded holes
1991 fj1200
Flynt
Flynt
Quote from: Motofun on January 19, 2021, 12:33:39 PM
Maybe you can do that, but I contend you will not put discrete perpendicular force as modeled by such a diagram...  I do agree that is the extension is shorter than about 1/4 of the torque wrench length, the difference will be negligible.  Imagine a 1 foot torque wrench and a 10 foot extension however, and the diagram will not reflect how you actually turn the bolt...
Quote from: aviationfred on January 19, 2021, 03:23:35 PM
I figured out what goes there. :Facepalm: Those are the bolt holes for the OEM collector box mount bracket that I dont need.
