Oil pump pickup removal.
Started by Paul.1478, September 05, 2020, 06:07:25 PM
Paul.1478
I am changing the oil pan gasket due to small leak.
When I removed the oil pan the gasket that goes around the middle bolt and the oil pickup split.
So now I need to order that and remove the pickup to replace it.
Looking at the parts diagram looks as if there are 2 screws.
Anyone know how to get the screen off so I don't F that up also?
Thanks.
Paul
2006 GL1800
2022 Ducati V2
1976 RD400
1993 FJ 1200 ABS
You have to gently pry the screen off the bottom of the oil pump.  Always good to clean out the screen - amazing how much junk they accumulate!
Cheap insurance to replace it while you have it off. You will know you have a clean one and no concerns of the screen being worn and tearing out.
Call Robert on Tuesday and he can add it to the order.
Paul.1478
Ok. Thank you.
And yes Randy I will do so. Thanks.
2006 GL1800
2022 Ducati V2
1976 RD400
1993 FJ 1200 ABS
