Fj1100 fuel issues - fuel tap and filler cap
Started by Jemiss, August 23, 2020, 12:26:48 PM
Jemiss
Hi Everyone
My FJ 1100 has two issues, the fuel tap leaks due to the vac diaphram which I can get a kit to fix. However my filler cap leaks as well. New filler caps do not seem to be a thing for the 1100 so is there a repair kit available? I think one of my worst nightmares is to end up in an accident and then covered in petrol!
84 FJ 1100
85 FJ 1100
Hello Jemiss, welcome to the forum.
Fix your petcock, that's most important....don't forget to safety wire the petcock elbow.
http://www.fjowners.com/index.php?topic=3265.0
On your tank cap, you want the cap to let in air as your fuel level drops so as to equalize the pressure.  Without some sort of relief vent, the fuel flow to your carbs will slow to a point of starvation.
Now, that being said, FJ's sold in Califorina, USA had a special fuel tank venting system that prevented fuel vapors from escaping the tank. Those Calif. Models had sealed tank caps. This was an emissions feature not a safety feature. If you have one of these FJ's (Calif Model) and you want to remove the vapor recovery system, all the hoses and charcoal canisters,  you will need to alter your cap to be able let the air pressure equalize in your tank.
In short, I would not worry about a fuel cap that leaks fuel...it also draws in air, which is a good thing.
Fuel leaks from the cap? Not a concern...
I never fill my bike on the center stand.
Reason: If I fill it too full when on the center stand, the fuel will leak out the cap when I put my bike on it's side stand.
I always fill my bike on it's side stand.
Along with the safety wire on the petcock elbow another important point on the early '84-87 FJ's is making sure your fuel line follows the correct route. You can pinch your fuel line and starve your carbs if not...
http://www.fjowners.com/index.php?topic=18286.0
When you get a chance, check in over at the Introductions section and tell us about yourself....
Cheers Laddie!
Pat
Jemiss
That was the reason I had taken the tank off!
Your fuel cap should not leak fuel everywhere, if it leaks on the side stand there is a problem! If you have an accident and you are on the underside of your bike and it is leaking fuel all over you there is something wrong and you have a high chance of dying.
I have never had such issues with any other of my bikes, and I do not wish to have it with this one.
84 FJ 1100
85 FJ 1100
If your fuel cap leaks fuel when your bike is on its side stand, something's wrong.
You have overfilled your fuel tank.
My point is simply, unless it's a Calif model, the 84/85 FJ1100 's caps are not air tight.
If you hold the tank upside down, fuel will leak out the vented cap.
Question:  Is it leaking because one of the locking pins unique to the 1100 is broken or missing?  Here's a little write-up I did for the repair of mine.
http://www.fjowners.com/index.php?topic=13921.msg146760#msg146760
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
Jemiss
That thread was exactly the answer I was looking for!
Thank you
84 FJ 1100
85 FJ 1100
Quote from: Jemiss on August 25, 2020, 04:55:30 AM
Thank you
We got your back!   :good2:
'06 KTM 200XC
