New Shock and Relay Mods
Started by RevDeal, July 08, 2020, 10:15:13 AM
RevDeal
Well no need to go crazy in depth, but I set out to change the shock because it didnt feel good in the corners, almost a little sketch. While waiting for the Hagon shock from the UK I tore into the electrical to add a USB charger. Then I had to address previous owner's wiring.TLDR version
1. Hagon Shock upgrade $375 (shipped)
2. USB dual charger w/ digital volt display, cigarette lighter, and switch (amazon) $22
3.Terminal bus for positive wires, 4 new relays, new colored wires and heat shrink $50
4. Headlight relay mod, horn relay mod, and coil relay mod, and usb charging bank install (time, lots of time)
5. Repainted inner fairing black
1992 FJ1200A (ABS Delete)
1980 CB750k (gone to a new home)
Quote from: RevDeal on July 08, 2020, 10:15:13 AMWell no need to go crazy in depth, but I set out to change the shock . . .  I tore into the electrical to add a USB charger. Then I had to address previous owner's wiring.TLDR version
RevDeal,
Got a link for that USB gadget?    :unknown:
RevDeal
