Wheel bearings SKF 6302 z
Started by Old Rider, June 26, 2020, 09:03:35 AM
Old Rider
Has anyone tried the SKF 6302 Z bearings on frontwheel i read that they are for washing machines but skf is top quality.
I tried allballs 2 times and they where toast after a couple of months.
Here in Norway
SkF cost 10 usd for 1
Genuine yamaha cost 35 usd for 1
TomJK
http://www.fj1200-3cv.de/_FJ1200/01-Fahrwerk/Lagerabmessungen/lagerabmessungen-FJ.htm
I use them, till now, done 30000 km no problems, cheaper still in Germany, many suppliers....
Cheers, Tom.
Past bikes : BMWR90-S,BMW R100CS, Ducati 900SD, Kawasaki GPZ600,Yamaha FJ1200,Kawasaki ZZR 1100 (4x),Kawasaki ZZR1200, Honda CBR1100XXX,Yamaha Thunderace, Kawasaki ZX10R (3X),
Aprillia Falco,Honda CBR600F4I, bikes today : Kawasaki ZX10R (C1, the best!),Yamaha FJ1200, soon to come Kawasaki Z900.....
Old Rider
Quote from: TomJK on June 26, 2020, 09:54:09 AM
Cheers, Tom.
Okay thats good news after looking on you profile picture i can see they also work at a little speed  :smile:
Charlie-brm
SKF does make reliable bearings, i.e. manufacture bearings, not just import and distribute bearings.
That Z designation means the bearing is enclosed on only one side and with a steel shield. ZZ means a shield on both sides.
There are shields and then there are seals - different.
Finally online I saw the characters that prodded my memory when I saw them: 2RSH
That is 2 Rubber Seals. (H? I don't know what that's for).
I always buy the bearings closed on both sides with rubber/polymer seals: So 6302 2RSH if it is an SKF. I don't play with opening them and adding extra grease. The set I have in now were installed in 2014, used under Canadian weather conditions.
This site has excellent information on the designations; easier to digest than the official SKF site.
https://www.qualitybearingsonline.com/6302-2rs-skf-deep-groove-bearing-15-x-42-x-13mm/
1979 XS750SF - 2005 to 2012
Old Rider
I know about the z or zz .The ones i have ordered has a picture showing that they have metalshield on both sides even if they are named with only one z hope they just named it with one z by mistake.
the genuine yamaha rearwheel center bearing has only 1 z  6304Z but has metal shields  on both sides if i dont remeber wrong?
CutterBill
Yes, SKF are top-quality bearings. You won't any problems with them.
Whenever I replace a bearing, I always use the -2RS (rubber seal, both sides.) Yamaha used shielded bearings (Z or ZZ) because they are a few pennies cheaper than the sealed bearings. And if you're curious, the letter after the -2RS denotes the type of rubber used. Sometimes that matters. In our bikes... not so much.
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Old Rider
Quote from: CutterBill on June 27, 2020, 05:08:24 AM
Bill
So then i learned somthing new today too i always tought that the bearings with metalshields was better sealed than the rubbershields ones after all some are used in washinmachines
Charlie-brm
Quote from: Old Rider on June 26, 2020, 11:28:31 AM
A lot of parts websites just repeat a similar "close enough" looking image to save time and some file space. 1000's of line items adds up to a lot of hours of web building time. That could explain the discrepancy. Another reason to support local outlets or at least mix it up once in a while as to where one buys things.
balky1
I was told to use NTN as those were the originals. Also cheap, I think definitely less than 10 USD for a piece if my memory is right.
FJ 1100, 1985, sold
FJR 1300, 2009
Old Rider
The bearings arived in the store for me to pick up some days ago and they had metalshield on both sides but they where named FAG
not skf. By that time i had done some more investigation about the metalshielded  and they are not sealed against water and dirt so i
asked if they could send them back and if i could make a new order (they had same price by the way) on skf bearings with rubberseals.That was okay with the store.
Old Rider
Quote from: balky1 on July 06, 2020, 03:49:51 AM
I tought that NACHI  made in japan was the orginal yamaha part but they are wery expensive at yamaha store and cant find another seller i Norway
The original bearings in my USA '84 were Koyo.
balky1
Quote from: Pat Conlon on July 06, 2020, 12:16:19 PM
Koyo, right, my mistake!
I've put Koyo, not NTN.  :rofl:
FJ 1100, 1985, sold
FJR 1300, 2009
Hasse
This was informative!
But I still have a few questions..
I have 2 SKF 6302-2RSH, and it looks like they go to the front. Right?
Then I have 2 SKF 6304-2RSH, looks like it`s rear center?
Then 1 SKF 6305-2RS1, dos it go on my -87 FJ1200 anywhere?
Then I have 1 KOYO 32006J HI-CAP. Is it useful for my bike?
Then I have 1 MBS 32005X, or is it SX? Is it useful for my bike?
Appreciate good answers. The season is about to start in northern Norway..
Old Rider
Hei Hasse og velkommen til forumet ! Kjekt å se en nordlenning her  :smile: prøver å svare deg jeg
Quote from: Hasse on May 14, 2021, 01:39:53 PM
I have 2 SKF 6302-2RSH, and it looks like they go to the front. Right? Yes they do
Yes but in a partscataloge https://www.cmsnl.com/yamaha-fj1200-1987-1tx-europe-271tx-300e1_model37295/partslist/0031.html i seen they are different  one outer on brakeside has rubbershields and the next nr 4 in illustration has one metalshield (Z)
don't think it matters if you use the rubber, but I'm not 100% sure i think i remember that the flange NR 3 in illustration will push on the rubber or something
Then 1 SKF 6305-2RS1, dos it go on my -87 FJ1200 anywhere?  This one goes in the rearwheel hub carrier outer left  in the catalogue it has metalshield but rubber has better protection against water
Then I have 1 KOYO 32006J HI-CAP. Is it useful for my bike? This is the lower steering stem
Then I have 1 MBS 32005X, or is it SX? Is it useful for my bike?  This must be upper steeringstem but not sure it fits
