Brake Upgrade for My FJ1100
Started by krusty, June 13, 2020, 08:34:16 PM
krusty
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
krusty
I should have mentioned that I already have '88 1200 forks fitted to the 1100.
It has stock wheels with early V-Max rotors. I'm guessing that with the stock 16" wheel, larger diam rotors, plus these calipers, should provide very much improved stopping power.
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
The R1/R6 calipers will work on your 1100 ONLY if you have 88 or later forks, 17 inch front wheel and 298mm or 300mm rotors.
Using the brackets in the following link will allow you to use the R1/R6 calipers with the 1100 anti-dive forks and the 282mm rotors and the 16 inch front wheel
http://www.exactrep.com/acatalog/Front-Hanger-Brackets--pair--12B.html#SID=22
Holy crap Kriusty.......$150 Aus.......that seems mega expensive....glad I live where eBay prices are reasonable !!
krusty
I got a $20 discount so it was really only $130. Most I found were about $160-$170. Equivalent USD was about $90.
There were cheaper ones on US Ebay but shipping costs were horrendous.
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
Starquest
Mine is a 1986. 89 forks,gold caliper stainless braided lines, v-max rotors ,r1 master cylinder, on 16 inch wheel.
PaulG
Quote from: krusty on June 14, 2020, 06:24:20 PM
Ouch.  :shok:   I paid $25 for a pair of R6 blue dots with all the lines (which I didn't need) from the wreckers for my '92.  I guess when they have you over a barrell there's not much you can do.
1992 FJ1200 ABS
YouTube Channel Paul G
Bones
Quote from: PaulG on June 15, 2020, 09:35:00 PM
Occasionally you'll score a bargain here, I got an FJR front brake master complete with silver spot calipers for I think $120.00, but normally that price or higher would be for each. Nothing is cheap to buy here compared to other countries.
93 fj1200
79 suzuki gt250x7
krusty
Quote from: Starquest on June 15, 2020, 12:18:55 PM
As it is at the moment.
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
krusty
Blue spots arrived on Friday. They look good except the dust seals on one are toast. Pistons look ok but will know better when I have them out. Odd thing was they calipers had mixed pads. I'll see if I can get a pic of them.
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
krusty
Removed inner pistons today, all in good condition with no sign of corrosion. I'll remove the inner pistons when the special tool arrives from UK. August 2017 Classic Motorcycle Mechanics has a How To feature on R6 brake overhaul.
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
Go ahead and replace the seals on the inner pistons, reinstall the 2 pistons, then use a c clamp to hold the 2 inner pistons in place, now use your air compressor to blow out the outer pistons.
I do not recommend messing around with those blue spot buttons.
Over the years we have changed thousands of piston seals on the Yamaha monoblock calipers and have never needed a special tool or needed to remove those buttons.
krusty
Still waiting for the seals to arrive and also a dental pick off Ebay which will make it easier to get the old items out of the bores.
In the meantime I've been kept busy. Ever had one of those experiences where one simple job leads to another - and another?
I noticed the clutch was also weeping on the 1100 so I fitted new seals (which arrived a couple of days ago) to one of the M/cs I'd already cleaned up. Fitted that to the bike and bled the clutch, again no trouble there. However, when I had finished and cleaned up I wheeled the bike to the back of the garage and noticed it was hard to push. I put the bike up on the centre stand and tried to turn the rear wheel (in neutral) - I could hardly move it. I instantly suspected that the tiny pressure relief hole in the rear m/c must be blocked with crud. I've come across this problem before on other old(er) bikes.
As it happened, a friend of mine had recently sold his 1200 and had a box of parts left over from when he rebuilt it a few years back. He offered them to me, gratis. Among the stuff was a complete, clean rear, brake system. I checked it over and checked the little hole in the m/c and all looked very good. The pads that came with it were almost worn out but the pads on my 1100 were excellent as I had replaced them when I got the bike about 3 years ago and they haven't done a lot of Ks.
It was a straightforward swap. Out with old and in with the new. Bled the system and all was good again. This afternoon I took it for a test ride and all went well, only thing I had to adjust was the brake pedal.
The old brake system is now stored along with my other brake bits ready to be overhauled for another 1100 I am working on.
Something I just thought of. It wouldn't start while in gear with the clutch lever pulled in. I checked the lever switch and it tested ok. Is there something else that could be at fault?
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
T Legg
The kickstand has to be up also when it is in gear to start.
T Legg
