does anyone know the size and type of fastener used to secure pickup coils 1985
Started by mtc, June 08, 2020, 07:51:54 PM
mtc
i think is M6
but what is the length?
and head type
i could use cap screw right?
and is there a washer in there?
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
I dont know the length, diameter or thread pitch, but the bolt, washer and nut are available new from Yamaha. #11, #12, and #13 in the diagram
https://www.partzilla.com/catalog/yamaha/motorcycle/1985/fj1100n/electrical-2
mtc
Quote from: aviationfred on June 08, 2020, 08:55:51 PM
thanks but looking for the bolts that hold the pickup plate, not  the rotor
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
MTC,
Decode Yamaha bolt numbers here:
https://www.yamahastarbolt.com/technical-library/decode-yamaha-part-numbers/
Once you have the correct Yamaha Part Number for a bolt, scroll down and find the Part Number grouping that matches your number, on the linked web site.  Digit locations indicate the specs of the bolt.
My apologies, I misread your post and listed the bolt that is for the main coils.
I believe what you are looking for are the 2 small bolts in this diagram. #5 in the drawing. They are available from Yamaha and probably RPM.
https://www.partzilla.com/catalog/yamaha/motorcycle/1985/fj1100n/pickup-coil-governor
Old Rider
If i remeber right you can use the same bolts used on the top camchain guard.
From the part number: 98517-06012-00
It's an M6 x 12mm long.  The stock screw has a captive washer.
Should be able to get one at any hardware store
mtc
Quote from: FJ_Hooligan on June 09, 2020, 10:29:43 AM
thank you everyone, i am sure it is M6 since that is what the dyna instruction says, but it's 20mm long, i guess i can use a cap screw head, i just needed the length,
when i click on the  screw i see no washer
https://www.partzilla.com/product/yamaha/98517-06012-00?ref=c781fe29972bf8524f07297f5deed185810b3760
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Quote from: red on June 08, 2020, 09:10:04 PM
MTC,
thank you very much
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
If you use the link Fred provided, the screw is listed as: SCREW, WITH WASHER
mtc
Quote from: FJ_Hooligan on June 10, 2020, 02:35:55 PM
thanks, i just went and bought hex cap screws but it is still no washers
but i keep looking for sizing, where did you actually see the m6/12mm sizing?
https://www.ebay.com/itm/Yamaha-OEM-Pan-Head-Screw-98517-06012-00-/152464088061
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Sparky84
Quote from: mtc on June 12, 2020, 12:47:33 AM
Quote from: Pat Conlon on June 11, 2020, 05:36:44 PM
Read the #5 part number ^^^ 9857-06012-00
See the middle numbers? Diameter comes first, then the length.
sorry need to be spoon fed everything, thanks
Are you still in the high chair at home   :biggrin:
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Keep yer heads low, squad; snipers are in the area!
We'll get everybody through, just hang tough.
