FJowners.com
October 02, 2022, 10:26:04 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: This forum is run by RPM and donations from members.
   Home   Help Login Register
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14   Go Down
  Print
Author Topic: Bryan's 1989 FJ1200 rebirth in Poplar Grove, IL  (Read 46355 times)
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #165 on: July 10, 2020, 11:24:03 AM »
Bryan, for emission reasons the USA FJ’s were factory jetted lean with the #37.5 pilot jets.
Those small jets seem to clog easily, especially on gravity flow FJ’s. Remember, you are dealing with a 35 year old tank without the benefit of a proper fuel filter.
Perhaps it’s time to spend $25 for some new #40 or #42.5  pilot jets?
The slightly larger openings seem to be more resistant to clogging.
http://rpmracingca.com/proddetail.asp?prod=Carb%3APilotjet
Logged
2) Don’t store your FJ with E10 fuel https://tinyurl.com/3cjrfct5
4) Important items for the ‘84-87 FJ’s:
Waiex191
Sr. Member
Offline Offline
Gender: Male
« Reply #166 on: July 10, 2020, 11:56:28 AM »
Thanks Pat!  I wish I knew that before.
What is improper about the OEM fuel filter?
Logged
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #167 on: July 10, 2020, 12:22:41 PM »
Oooops sorry, my mistake, I had your bike mixed up with an ‘85...
I see now you have an ‘89 fuel pumper with a “proper” fuel filter.
I was referring to the earlier FJ’s that don’t have the benefit of a fuel pump or a “proper” fuel filter. Those FJ’s are gravity flow and just have a sediment screen on the petcock. Marginally effective at best.
Your fuel pump/filter system is much better at stopping the crud from reaching your carbs and the pilot jets, which seem to the the first stop for the fuel tank crud.
Still....you have the small lean #37.5 pilots. Other than in the USA, I think all the other unrestricted FJ’s sold thru out the world, had richer #42.5 pilot jets.
Sorry for the cornfusion.....
Logged
Waiex191
Sr. Member
Offline Offline
Gender: Male
« Reply #168 on: July 12, 2020, 05:04:01 PM »
I think we can close out this rebirth thread.  I put the airbox back on, balanced the carbs with the gauges first then my ATF manometer after.  I ended up turning out the bleed air jets a few turns and had to turn the idle down.  Whoever designed that idle adjustment is a sadist. I only got a few burns.  Here is it running after those adjustments:
https://youtu.be/UUODLvq7Szk
I put a petcock as a disconnect for my new fuel lines & pump.  The brass fittings really bite into the fuel line and are hard to remove.
Rode it about 40 miles.  Smooth, powerful off the line, idles great. Runs like an FJ.
Thanks to all for the help and encouragement, not to mention the parts from RPM and woodcreerkpete's carbs.
Logged
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #169 on: July 12, 2020, 08:56:48 PM »
.... Whoever designed that idle adjustment is a sadist. I only got a few burns.
Glad to hear it's all sorted and running well. For future reference, if you crack the throttle slightly it will lift the idle adjusting screw off it's seat, making it easier to turn. As for the burnt hands, you get better at it with practice but a gloved hand is always the better option.
Now, ride and enjoy.
Logged
"Tell a wise man something he doesn't know and he'll thank you, tell a fool something he doesn't know and he'll abuse you”
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #170 on: July 12, 2020, 09:55:26 PM »
There are notches on the idle nut that fit a long shank flat blade screwdriver quite nicely.
Reaching in from the right side (throttle side)  push on the rear side of the nut = idle goes down, front side = idle goes up.
Logged
T Legg
Hero Member
Offline Offline
Gender: Male
84 FJ1100 x 2
« Reply #171 on: July 12, 2020, 10:27:33 PM »
         I bet you eat pizza with a fork Pat   That's how I have to adjust the fuel screws on my rs carbs.
Logged
T Legg
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #172 on: July 13, 2020, 12:08:39 AM »
 rofl
Logged
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #173 on: July 13, 2020, 07:36:42 AM »
...That's how I have to adjust the fuel screws on my rs carbs.
Travis, you know they make a low profile 90 degree 1/4" drive for that?
Motion Pro make one at $165. It costs that much because it's a "carby" tool.
The same thing can be bought as a general tool for a quarter of that or you can use what I do, a $7 / 90 degree 1/4" drive elbow (below).
Logged
T Legg
Hero Member
Offline Offline
Gender: Male
84 FJ1100 x 2
« Reply #174 on: July 13, 2020, 10:03:06 AM »
Thanks Noel. I've heard rumours of their existence but I hadn't actually seen one. That tool would pay for itself.I'll check it out next time I get access to a real computer (most of our motorcycle shops have poor tool selections). I have made index marks on my fuel screws and carb body's to keep track of where they are set but it would be nice if the tool has a one to one turning ratio between the knob and the bit.
Logged
T Legg
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #175 on: July 14, 2020, 01:10:52 AM »
.... I have made index marks on my fuel screws and carb body's to keep track of where they are set but it would be nice if the tool has a one to one turning ratio between the knob and the bit.
As you can see Travis, it is 1:1 and the handle body and turning section are made in such a way and marked so turns can be easily measured by both eye and feel...
The handle has a detent ball which corresponds to the marked graduations. This can be removed, as shown below, for a continuous action if you wish to use it as a screw driver rather than an adjusting tool.
Logged
Administrator
Super Hero Member
Offline Offline
Gender: Male
Team RPM
WWW
« Reply #176 on: July 14, 2020, 06:21:55 AM »
Travis, if you are looking for that tool, I can supply it. We used to stock it, but took ot out of stock because it wouldn't work for adjusting the idle knob of the FJ.
Let Robert know if you are interested.
Logged
FJ1200W
Bronze Contributor
Hero Member
Offline Offline
Gender: Male
Columbia, MO USA
« Reply #177 on: July 14, 2020, 07:02:00 AM »
Travis, if you are looking for that tool, I can supply it. We used to stock it, but took it out of stock because it wouldn't work for adjusting the idle knob of the FJ.
I'm not chuckling. OK fine I did a bit.
$74.99 should be about right -
https://www.motionpro.com/product/08-0229
50 inch pounds maximum - very light duty use.
I've not needed this for my FJ, but hey, tools are cools.
 hi
There is always the POS version
https://www.harborfreight.com/quick-release-hex-socket-extension-and-angled-bit-holder-96726.html
Logged
Columbia, Missouri, USA, Earth
I'm am half as fast as 'half-fast', the fastest slow guy....
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #178 on: July 14, 2020, 08:29:51 AM »
....50 inch pounds maximum - very light duty use...
...There is always the POS version
You're right FJ1200W, they are light duty, this particular tool is not a general purpose 90 deg drive but a purpose made carby adjusting tool
I have a number of the POS variations, the most recent one (as pictured in your post) only cost $7 on eBay and has proven to be surprisingly robust and does the job. They are fine for general use but if I had a bike with carbs that needed constant fiddling, I might actually consider one of these, they tick all the boxes for features one would want with such a tool.
As a tradesman I am special tool averse unless it's absolutely necessary, which is not often, but this is a well designed tool for a single yet specialised job, I like it.
Randy, it would be easy to make an adapter that would grab the FJ idle thumbscrew but it seems a bit superfluous when it's so easily reached by hand.
Logged
RPM - Robert
Administrator
Hero Member
Offline Offline
« Reply #179 on: July 14, 2020, 08:50:44 AM »
Noel the adapters that come with the MP tool fit the idle adjustment screw itself. However, the height of the tool itself hits the case right below the idle adjustment screw and will not fit in between to adjust.
Logged
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
