what does the switch on the sidestand do
Started by mtc, May 11, 2020, 11:51:27 PM
mtc
i can't for the live of me figure it out, this is a 1 response thread
i have ridden off with it down more than once, so if it were meant to warn me , it does not
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
Quote from: mtc on May 11, 2020, 11:51:27 PM
i can't for the live of me figure it out, this is a 1 response thread......
....haha, and normally would have resulted in 20 responses. It is to stop you putting it in gear with the engine running, to avoid what you say you've already done a number of times. If you've ridden off with the stand down, it's either not working or it's been bypassed.
Old Rider
If the sidestandswitch works the engine will not run when sidestand is down so it has been fiddled with.
If you have ridden off with it down i suggest you start a new take off safety prosedure where you ALWAYS  take a look down and check that the sidestand is up before you take off. Not cool when you are going into a left turn at some speed.
RPM - Robert
Quote from: Old Rider on May 12, 2020, 03:25:29 AM
This is incorrect. The engine will run, until the bike is placed into gear with the sidestand down. It will also run while in gear with the sidestand down, if the clutch is held in. Unless, one or or both has been bypassed or is no longer functioning.
1 response each orrrrr.........?
Quote from: RPM - Robert on May 12, 2020, 10:46:50 AM
I believe this is also incorrect.
As far as I know, my FJ works "As it should, from the factory"
If I have the side-stand down, even if I am holding the clutch in, as soon as I click it into gear it kills the engine.............
The only time it should run with the side-stand down, is if the transmission is in neutral.
Just to add to the 1 response.
Part of the training course way back in the 80s focused on a final glance down to check the side stand, before looking over shoulder, then the off. This preflight dance is now ingrained and I think it's good practice.
I'm even in the habit of giving it a touch with the left boot.
RPM - Robert
Yes, Alan you are correct. I was backwards, was thinking of cranking it in gear with the clutch in and sidestand up. Haven't had my coffee yet.  :morning1:
1 response doesn't get it sometimes.
See, turned out to be a decent running thread.
Anymore for anymore?
mtc
Quote from: Firehawk068 on May 12, 2020, 11:10:24 AM
so what is the formal name called?
it would be better just to have an idiot light on the dash
where is it connected? i have an aftermarket ignition system, would that be the cause of it not working, since I heard so many different scenarios, do they tend to not work?
do new bikes have this safety switch?
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
i will i am such a skittish rider lol
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Is there an orange wire on your Dyna ignition wire harness?  If so, that wire needs to be connected into the sidestand circuit.  Your switch mist have a jumper wire installed
mtc
Quote from: FJ_Hooligan on May 12, 2020, 11:58:50 AM
yes sir there is an orange, i have to check, but like i mentioned that dyna is on it's way out, so the stock wiring is connected to the igniter? and a kill switch?
so in gear with the clutch  released, the engine is "killed"?
or rather if in gear, it will never run or start
and with the clutch out in netrual the engine is allowed to run?
and with the sidestand up the switch is grounded? or open?
i guess it's not that simple after all
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Side stand down in any gear except neutral, engine off.
Circuit is normally closed.
Side stand up, circuit closed, engine runs.
Side stand down, circuit open, engine off.
Old Rider
Another thing i usually check before takeoff is that my shoelaces is tucked under so they don't tangle up in gearlever or brakelever kinda embarrassing when stopping at a red light and  you just fall over.
Here is a vid of a sidestand down crash
https://www.youtube.com/watch?v=5mQ-5mWNOLo
Quote from: Old Rider on May 12, 2020, 12:34:51 PM
Where is Carson City Paul?  He didn't fall over....but it was close.
