Missing spark
Started by Jepjep, May 09, 2020, 12:11:38 AM
Jepjep
Hello. My -90 fj is missing spark from cylinders 2 and 3. Ignition coil is good. It has constant power in the connector, when turn power on. Other coil connector does not and gives good spark. Could it be CDI-box?
Thanks for responses, and sorry my english....
T:jyri from finland
Check grey wire for continuity to gauge cluster.  Also check for good ground from coils.
Jepjep
Could be, rpm gauge wont work either.
Sparky84
Have you swap connectors with 1 & 4 and then see if 2 & 3 have spark.
At least you'll confirm coil is ok
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Troyskie
Quote from: FJ_Hooligan on May 09, 2020, 12:21:05 AM
Sage words  :good2:
Troyskie
Quote from: Sparky84 on May 09, 2020, 01:09:08 AM
More sage words  :good2:
Troyskie
Quote from: Jepjep on May 09, 2020, 12:37:51 AM
That is the worst scenario, but possible. I've one dead tacho too. It is pretty unusual for them to die though.
