Firmer than expected front brake lever after Spiegler installation
Started by aigram, May 06, 2020, 12:46:30 PM
2big
Evening gents Nice tidy FJ1300 Nissin 14mm front master cylinder arrived courtesy of a well known internet auction house for the princely sum of 22 of your English pounds - very good condition, cheaper than repainting the old FJ one. Deal! thanks for your help and advice guys, now for the discs....
Jan
2big
Quote from: Millietant on May 27, 2020, 05:08:15 PM
And a nice, adjustable-span brake lever too Jan  :good2:
Yes got there in the end. Thanks Dean. Looks great but the adjustable dial is a bit stiff and in need of freeing off
Next up is discs (as we have discussed before) - Skywave in the UK is £125 a set, Arashi is £165... apart from the branding I can see the Arashi has a min thickness of 4.5mm where as the Skywave is min 4mm. They look the same but probably don't come out of the same factory.
Any experience or recommendations out there?
A set of fazer discs start at 4mm. Surely thinner is better and lighter or are thicker ones better, less prone to distortion and last longer. I assume the pads will always take up the slack with good bleeding.
Quote from: 2big
....... but the adjustable dial  is a bit stiff and in need of freeing off
/quote]
If you push the lever forward, to unload it, it will be easier to turn.
2big
Quote from: ribbert on May 29, 2020, 06:04:20 PM
Quote from: 2big
/quote]
Thanks for the tip Noel...
Quote from: 2big on May 29, 2020, 05:43:36 PM
I've never had a set òf discs wear out or go bad me on any of my bikes, even doing a lot of track miles. So far, my Skywaves are perfect after 2 years, and my standard ones on the FJ were still perfect after 77,000 miles.
Not sure why other people have so many issues - although my track day riding is mainly spent trying to keep up corner speeds and minimise braking  :sarcastic:
