Grip install
Started by Firecop119, April 04, 2020, 01:33:18 PM
Firecop119
Hello all. I'm trying to install new aftermarket grips on my 92 and on the throttle side there is a lot of slop now seems like on the cables. Just feels loose all together. Was thinking this should have been an easy job. Anyone ever run into this kind of problem. Thanks.
JPaganel
Are you installing the grip on the original throttle tube? Or is your grip the type with new tube built in?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Firecop119
I'm replacing with ones that have the tube built in.
Quote from: Firecop119 on April 04, 2020, 07:13:00 PM
Are they the proper bar diameter and cable spacing?
Firecop119
I bought these off eBay and they say they fit an FJ. I know the bar size is ok but the diameter of where the cables hook up might be a hair smaller. Would I just need to adjust the cable tension?
