Let’s talk cruise controls.
Started by Ted Schefelbein, March 04, 2020, 04:06:13 PM
Ted Schefelbein
I was shopping around on the internet that Al Gore Jr. invented, and trying to find a throttle lock type cruise I used to have on a 750 GSXR (I know, my bad) back in the day. I thought it was called a throttle-master, but, I couldn't find it. It was well made, seemed like stainless, replaced the bar ends, and, truth be told, I couldn't have ridden the bike the distances I did at the time (both coasts on that little guy) without it.
Fast forward 25 years, and I am looking to get back on an FJ, and would like a similar device to give my throttle hand a break from time to time on longer rides. Advancing age has brought about some numbness that crops up here and there as well. My hand needs a break here and there.
Anybody? I wasn't really looking for an electronic system, just a well made throttle lock.
Thanks in advance.
Ted
1989 FJ 1200
TexasDave
They still make the Throttle Meister throttle locks. I have them on two of my FJs. They look good on the bar ends. It takes a little time to get them adjusted just right with the shim washers but once adjusted do work good.
Ted Schefelbein
Thank you very kindly. Looking on the web with the correct name should help.
Is there any preference on parts dealers who carry them? Do parts dealers carry them?
Thanks,
Ted
1989 FJ 1200
Ted Schefelbein
I looked around a bit, but, it doesn't appear that the throttle meister is available anymore.
Ted
1989 FJ 1200
PaulG
Quote from: Ted Schefelbein on March 04, 2020, 07:52:33 PM
Ted
BTW one word  - Throttlemeister
I think they're out of business according to several other forums I've come accross
I found these:
http://www.hardracing.com/Throttlemeister.htm
This ebay link lists them as bike specific, but I thought they would fit any 7/8" bar, no?
https://www.ebay.ca/sch/i.html?_sacat&_mPrRngCbx=1&_udlo&_udhi&_sop=12&_nkw=throttlemeister&rt=nc&LH_PrefLoc=2&_trksid=p2045573.m1684
Twisted Throttle has similar types
https://www.twistedthrottle.ca/shop-by-product/ergonomics-rider-comfort/throttle-locks
1992 FJ1200 ABS
YouTube Channel Paul G
Here's what I use, it's simple and works great.
Got mine from Dennis Kirk but I'm sure it's available from other places.
https://www.denniskirk.com/avon-grips/black-anodized-small-icruz-throttle-lock-icz-sm-ano.p1911986.prd/1911986.sku
'94 Yamaha WR250
Carson City Paul
You might want to take a look at the Omni-Cruise. It is the same principle as the I-Cruz, but appears to be a little nicer.
Alf
I´ve been using Vista Cruise since 2003 and more than 300.000 km. in all the bikes that I´ve owned. Simply to fit & excellent
https://www.ebay.co.uk/itm/Vista-Cruise-Sound-Off-Recreational-MCVICO-P/112385148734?epid=171164324&hash=item1a2aad473e:g:rgAAAOSw7oheWVU8
I have the Throttlemeister, but I never use it. The one I have used can be purchased from our host. The paddle-type is very effective and easily adjusted.
RPM Crampbuster
Ted Schefelbein
Host? I'm your huckleberry. Let me know!
Ted
1989 FJ 1200
My post may have been confusing. I meant to say that I have the Throttlemeister bar ends installed on my bike, but I don't ever set the cruise. I got them for that, but I found I just never use it.
The one that is pictured above, which can be bought from RPM is one that I had used for several years before I bought the Throttlemeisters. It was a simple plastic paddle that would grip when twisted in one direction, and slip in the opposite. It simply sits under your palm and lets you hold the throttle without gripping the handle with your fingers to twist.
roverfj1200
1988 FJ1200
Richard.
Carson City Paul
The Vista Cruise are nice. Pat and I have them on our bikes.
They take up very little throttle space and are easy to use.
The only down side I have found with them is, if you forget to release it and continue to use your throttle, it will wear a grove and eventually cut thru the nylon throttle tube. The continual rubbing will do the same (over a long period of time).
When I was at RPM replacing my throttle cables Robert and I caught that during the change and I had him install a new throttle tube. It would suck to have that wear thru 300 miles from nowhere.
Thanks again Robert.
Dieselman7.3
Probably not the best way but my dad told me back in the day they would slip an o ring between the grip and bar end... works decently but but you have to manually roll the throttle back.  Real cheap to do
85 fj1100
89 fj1200 - was for parts now a new project
16 Versys 650 - for off payment riding
Past:
05 ex500
78 Ltd750
