Shim under bucket conversion
Started by Indiana jones, February 08, 2020, 05:31:20 PM
Indiana jones
For racing application.
I do know that Suzuki Hayabusa buckets fit the stock valve springs and the Suzuki retainer will also fit with a little machining.
Has anyone got more info?
BMW R1150GS,XT600 Tenere,FJ1100 bobber, Ducati 999 BiP x 2
FJ1200W
I don't have an answer, but found a similar set up in my motor -
Columbia, Missouri
USA
Quote from: Indiana jones on February 08, 2020, 05:31:20 PM
I've heard of using the Busa buckets - but not the retainers - cool.
I'd like to know the details of the required machining to get the Hayabusa retainers to for the FJ.  Opening them up from 5 mm to 5.5 mm for the larger FJ valve stems - but is there an angle required to match with the keepers?  Or is it a square cut?  Any machining required to mate with the ID of the FJ valve springs?  Is the OD sufficient for the FJ springs?
Are the Busa retainers known for ovaling like the aftermarket retainers?
Indiana jones
Quote from: FJ1200W on February 08, 2020, 07:36:00 PM
That's a very nice looking set up.
Trick looking retainers.
I would love a set up like this.
FJ1200W
Quote from: Indiana jones on February 09, 2020, 04:21:41 AM
Thanks for the kind comments.
WebCam and others have them - Here is a link
http://www.webcamshafts.com/pages_vehicles/motorcycle/yamaha/1764.html
Columbia, Missouri
USA
Are those shim under buckets designed to rotate so the surface wear from the cam lobes are evenly distributed?
Chris, have you ever had a problem with spitting out shims with your race bike?
Pat, never had an issue with spring a shim.
The land speed engines have both run stock buckets and shims with no issues.
The drag bike engine was shim under - did have several of the titanium retainers oval out.  Seems to be a fairly common issue on the shim under conversions.  I have been told having the retainers DLC coated helps with the issue.
The Busa retainers are steel - so I imagine no ovaling issues.  BUT, I imagine they are heat treated.  I wonder what type of issues machining them may cause?  By the time you machined them and got them re-heat treated, may be better off with titanium retainers and getting them DLC coated.
Indiana jones
Is there a vendor for the Ti retainers?
Indiana jones
Quote from: FJ1200W on February 09, 2020, 10:38:52 AM
:Facepalm: Just reread your post!! Perfect. I shall be getting some
JMR
Quote from: fj1289 on February 08, 2020, 10:59:02 PM
No....they don't oval. They are hard anodized aluminum as opposed to raw titanium (which eggs out). Ti works if they are DLC or Ti nitrided. Latest Ti retainers take a 9.5mm shim as opposed to the 13mm shim.
JMR
Indiana jones
It seems that the Busa retainers won't work.
I got bad info. The collet groove to valve tip is too long on the Yamaha valve. The shim doesn't sit into the recess in the Busa retainer.
It looks like the Busa buckets would work with the kibblewhite retainers though, with the 9.5mm shim.
JMR
Quote from: Indiana jones on February 10, 2020, 06:35:09 AM
That's good considering the price of Kibblewhite buckets. There are probably 1 million used busa buckets out there. :good2:
This looks like another possible option — I have not tried it — so there could be some snag I'm not aware of.  It looks to me like you could use it with stock style retainers and not have to worry about the titanium retainers ovalling out.
https://shop.kpmivalvetrain.com/p/tappet-shim-in-tappet-ht-steel-28-00mm-od?pp=24
