Project Motor Swap
Started by FJ1200W, February 07, 2020, 03:13:24 PM
FJ1200W
Does anyone know if there a "kit" with all the lower end gaskets/seals/orings/etc or do they need to be ordered individually?
Columbia, Missouri
USA
Quote from: FJ1200W on March 25, 2020, 06:07:42 AM
Maybe this will have everything that you need.
http://rpmracingca.com/proddetail.asp?prod=CompleteStarterClutchKit
Steve, 20+ years ago there was a couple of aftermarket complete gasket kits. Unfortunately the quality was substandard and they had a ton of issues. I got one with a basket case I bought many moons ago and the lack of quality was obvious.
I'm working from my phone, so I can't see the photos very well. But usually, the trans needs to be removed so the drive cogs can be inspected.
I'll have a look this weekend when I get to the shop.
FJ1200W
Quote from: racerrad8 on March 25, 2020, 06:50:57 PM
Robert is all over it, thank you!
I'll pull the trans apart and we'll see what we see.
Thanks again, pic's to come
Columbia, Missouri
USA
FJ1200W
Columbia, Missouri
USA
FJ1200W
Oh the joys of working on something someone else worked on before.
When I split the cases, I found the center oil passage was plugged. Or restricted, I was not sure which.
After much thought, I tried to remove it with a pick, but it was in tight.
So, in my infinite wisdom, I used a tap - threaded it in, put some vice grips on it, a plastic hammer for leverage, and just like magic -
I broke it off in the plug. Or restrictor. Whatever it is. Was.
Luckily, time and patience won out, and it seems like the cases will be OK.
When the original builder removed the starter and related parts, he plugged the passage, for obvious reasons.
I have a transmission on the way, out of a 1993, so it should be undercut from the factory and - well, let's wait for it to arrive.
Shift forks, I'll order those from RPM, and then I need to decide on the shift detent roller - anyone install it and truly tell a difference? Stock spring or stiffer spring? Yeah or nay?
Many thanks for all the help
Columbia, Missouri
USA
FJ1200W
The passage plug.
I see sealant, it was tight.
I may remove that broken easy out just because it's the right thing to do.  :crazy:
Columbia, Missouri
USA
Why was that plug installed?
Yes on the RPM roller shift kit, use the stock spring.
FJ1200W
Quote from: Pat Conlon on April 08, 2020, 02:19:59 PM
The internal starter drive mechanisms were removed for Bonneville by the original builder.
He used that to block the oil passage to it.
That's my guess
I wanted to use the engine on the street and appreciate a starter. :D
Columbia, Missouri
USA
Ok, thanks Steve, yea, starters are a good thing.
Be sure to get the low profile oil jet for your starter chain:
http://www.fjowners.com/index.php?topic=19016.0
Speaking of starters, I just remembered, the Yamaha FJ1100 was the first motorcycle I have ever owned that did not have a kick starter.
I was concerned, but I figured I could always bump start it in a pinch....
Phew and timely question and a timely answer. I couldn't think of any good reason to restrict oil flows about the engine. It's the kind of condition nightmares are made of.
JMR
Quote from: andyoutandabout on April 08, 2020, 11:36:09 PM
People have routinely restricted oil flow in Hayabusa race engines (LSR and drag) to keep pressure higher where you want it to be.....main and rod bearings. Oil flow to the oil cooler is one of the primary areas restricted.
FJ1200W
Quote from: Pat Conlon on April 08, 2020, 04:14:06 PM
I'm considering that as well, but am on a budget......
Time to fire up eBay and turn some stuff into money! :D
Columbia, Missouri
USA
FJ1200W
The final hard parts have been ordered.
The transmission arrived, it is as represented. Looks fantastic in fact.
So excited.
Cabin Fever: Is real
Columbia, Missouri
USA
FJ1200W
Close to the final care package arrived today. (Not the transmission)
About time to lock myself in the garage.
I'm torn on whether to put the stiffer shift dent spring in or not - as this is not going to be a long distance rider, I'm leaning towards using it.
If I go with an air shifter and that might be a benefit.
Thoughts anyone?
Columbia, Missouri
USA
